Explorer 8.8 in to a 04 ranger
Diesel_brad
Gilbert PA
I am looking at doing this swap.
What year explore should I be looking for and what all would I need to hook my ranger drive shaft and e-brake cables up?
I am pretty sure I have a bent axle from overloading the truck and the backing plate is all twisted too.
I figure @ 200k the stock diff has has enough
Diesel_brad
Gilbert PA
Buler???
I was able to find out I need a 95-01 axle and I need to relocate the spring pads and shock mounts.
What about the e-brake and driveshaft?
chvlfrk
December 2010 STOTM Winner
MTOTM Winner
31
Niota, TN
Ranger XLT 5.0L
5.0L
235/70R15 front / 275/60R15 rear
No choice that I know of but to rig up the e-brake as you like....I used cable & chain.
As far as the driveshaft, look for a dual pattern flange on the 8.8 you buy.
Diesel_brad
Gilbert PA
I am having a hard enough time finding a 4.10 8.8
SenorNoob
567
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
It might just be bad luck, but try targeting 95-96 2-door Explorers with manual transmissions. Almost every 2-door I saw was manual with 4.10 gears. All 2wd..
Diesel_brad
Gilbert PA
Yeah. 2 doors no less stick are hard to come by. And 2wd?!?!? Not up here where we get snow
chvlfrk
MTOTM Winner
31
Niota, TN
Ranger XLT 5.0L
5.0L
Here ya go>>>
Not sure where exactly you are in PA, but try this site, as there are quite a few rearends like your lookin for across the state:
Car-Part.com
Diesel_brad
Gilbert PA
Car-Part.com
Thanks, I always forget about them
Diesel_brad
Gilbert PA
Ok, got an 8.8 from a 98 explorer. Came with rotors, calipers and E-brake cables. 4.10s but no limited slip. I am going to have a Yukon Dura-Grip installed and the the bearings and seals changed for good measure.
Right now I have the axle assem pretty much stripped of all the brackets and I am trying to figure out where to weld the new spring perches. I found this thread here that says 6* http://www.therangerstation.com/tech_library/Explorer8_8.shtml
but if I am measuring My stock ranger axle correctly I am getting 8.5* (but not the easiest to do with the axle still in the truck. Also I can see they need to be 38.5" apart but kinda hard to tell where side to side
Can anybody shed some light on the pinion angle?
don4331
1,346
Calgary, AB
5.3
The wimps way out (those who don't weld) - get the DJM brackets to lower an F-150. Installing them on top of Explorer axle will put the perches in correct location/pinion angle and you are done with the springs, then you just need to work out the shocks and swaybar mounts...
Solution #2: Cut mounts off your existing axle. Put the 8.8 on leveled jack stands on Explorer spring mounts. Place the mounts you cut off onto the 8.8 level and weld (aka parallel with the Explorer mounts). Explorer mounts can then be removed if desired.
Solution #3: Put 8.8 on jack stands on existing mounts; measure pinion face angle. Cut
off Explorer mounts, and reinstall on top, weld. If you only do one side at a time, you can maintain a reference and just keep mounts level.
Technically, the Ranger perches need to be a smidgen narrower than the Explorer's (equal amount on both sides) but there is enough compliance in the bushings/springs that you can install with them at the Explorer width.
My solution for the parking brakes was to calculate how much I needed to shorten the cable, then I took it to local garage door shop and had them swag ends on at the desired location. Works perfect on my daughter's '98 and looks so stock it passed the visual inspection.
p.s. Check the e-brake pads. My Explorer and F-250 both had ruined e-brakes...
Diesel_brad
Gilbert PA
Ok, NONE of you solutions help me since my mounts are already CUT OFF.
It will be getting all new e-brake hardware, shoes, rotors, calipers and e-brake cables
Diesel_brad
Gilbert PA
Well I got the axle in the truck today. Everything went smoothly up until the E-brake cables. I bought brand new Ford ones as not to deal with aftermarket junk.
I have my brake bracket relocated due to the chevy 1/2 ton springs I am running. I just welded a piece of square tubing to the spring hanger and then the brake to the tubing to keep in in the stock location. It has worked fine for the past 4 years and 100k.
But now I THINK I have the explorer bracket located on the bottom of the frame in in such a way it allows equal tension on both cables. but the PROBLEM is the passenger side cable will NOT stay on the small brake lever at the passenger wheel. It is aBEAR to get on and as soon as i release the e-brake, it springs right off. The cable can only go on one way, or am I missing something?
PLEASE help, I NEED an e-brake
Diesel_brad
Gilbert PA
I am pretty sure I figuered out the cable hoping off issue.
When i had the rear brakes apart and the E-brake lever apart to Un-seize it, I must have assembled the passenger side one wrong and it was not going all the way back to the release position and there for the cable could slide off the hook.
Went for a quick ride...
WOW, it stops on a dime now and I am pleased with my choice of the dura track post unit so far. Not grabby, but will easily spin the inside tire on a hard turn in gravel. Also the E-brake seems to hold better than the old drum brakes did
