HELP.. wipers don't work
dragginNCrds
4
my wipers have quit working and i have tried everything i can think of.. i pulled the multi switch out and tested everything with a ohm meter... changed the relays under the hood.. i am at a lost and i can't find a complete diagram for that system.. i am working on a 05 Ranger edge 2wd 3.0l please let me know if there is anything you can help with..
dragginNCrds
4
everything i have read says a 05 dosent have the GEM module
rtg143
ASE Certified Tech
61
Oregon
5.4l
I looked it up on my diagrams and they show pretty much the same. I can't send the diagram I have bur it shows the same.
dragginNCrds
4
ok.. all the wires at the relays are getting power.... and i have jumped the relays and the wipers move so i know its not a ground or a motor issue.. the multi switch puts out voltage... I'm at a lost..
kimcrwbr1
46
maplevalley WA
ford
2.8l
The motor has a end switch and full time power. Do you have full time power with the key on to the wiper motor? Trace that circuit.
Scroll down to 4 of 7 in power distribution you system should be similar. The module provides a pulse to the wiper motor and after the end switch closes the motor stays running until the end switch opens to stop the wipers in the down position.
http://www.therangerstation.com/tech_library/EDiagrams/index.htm
kimcrwbr1
46
maplevalley WA
ford
2.8l
After more research your wiper motor has the module built into it if you have key on hot to the motor the motor probably needs replaced. Be sure and disconnect the battery before removing any bolts. Check that the wiper motor is getting power with the multifunction switch on high speed (2) also.
dragginNCrds
4
i checked voltage at the motor.. i have power in pin 2 (Wiper High/low output Low)
Pin 4(power and run or acc) and then a good ground.. i didn't check pin 5 for the run park relay but i didn't have power on pin 1( Wiper High/Low output High)
would this mean i need a new multi switch.. because i check that spot at the relay and didn't have power there and the wire ohmed out good..
dragginNCrds
4
i also checked pin 5 and do not have power coming out the relay for that either..
dragginNCrds
4
come to find out it was fuse #6 for the radio my radio is aftermarket and was hard wired to another circuit thats why i didn't know it was blown.. thanks for your help though
rtg143
ASE Certified Tech
61
Oregon
5.4l
Glad to hear that it's fixed. Thanks for the update.
Staff online
Shran
April Truck of The Month
