twfmvm
- Dec 13, 2015
- Reaction score
- 0
- Make / Model
- Ford
- Manual
Update. Tightenting the torx screws did nothing. I replaced the voltage regulator and there was no change. I replaced the stator connector as well and it helped significantly. Still a little voltage oscillation. From what i read elsewhere resistance in the stator wire can cause these symptoms. Where does it connect to from the one wire connector?
Im aware the wiring diagram shows the stator wire goes back to the voltage regulator connector. I ask because i have the external voltage regulator and it appears to have different wire colors that are all unique. My stator wire is black/yellow
