Bronco 2 Steering Upgrade - Not Lifted
saab900
Blacksburg, Virgina
2.3?
Hy guys! So after some excursions in the wood there is no way I can get rid of this truck, so its time to do a bit of work! I had some 35 14.50'son the truck and it rode like hell because they were worn Thornbirds. Obviously getting a better set of tires will make it handle a lot better, but I re-did the whole front end steering system and it got somewhat better but not a lot.
I also did this with 2in blocks in the rear and no lift in the front. So my question is what if anything I can do to beef up the steering if I don't have a lift? I am hoping to pick up a Dana 35 here soon and I figured while I am in there it would be helpful to redo the bushings and upgrade the steering but aside from a steering stabilizer.
Thanks!
Alex
Phantom
2
Salida CA
4.0
Not knocking your rig, but I find this a little odd.. I guess you could of cut most of your fenders out..
richard booth
28
Tacoma wa
ford
2.9 for now.
If the front end has a lot of miles a complete rebuild IE new ball joints, tie rods and center link will do volumes. I just got the whole link system (center link and tierods) off of an explorer at the wrecking yard that had newer stuff. ground about an inch off each tierod threaded end and slightly adjusted the steering gear and my dd B2 tight steering. Pick n pull charged me 15 bucks for the links.
Members online
Today's birthdays
Shran
April Truck of The Month
