1-2" suspension lift . . .
PetesPonies
25
east coast
Ranger
2.3l
just making sure . . you can do a 1 or 2" suspension lift with no problems created other than possibly needing longer shocks right?? I run full size shocks anyway . . but am I correct here?
unoleisu
6
Stillwater, Okla
ford
2.9
On what? I put a 2" body lift on my BII last week and had no "problems", other than having to fab some radiator brackets and an engine ground extension that didn't come with the kit.
(that is if you don't concider having to cut old mount bolts off because they rusted solid, as a problem)
4.0B2
TRS Banner 2012-2015
151
Walls, MS
4.0 v6
suspension lift, varies depending on your personal truck... might need brakelines extended, will need alignment. it just varies
PetesPonies
25
east coast
Ranger
2.3l
Eagle Point OR
FORD
2.9l FI, 2.9L FI, 2.8L
For an RBV like your BII, you will need camber bushings to correct the camber after the lift. drop brackets are recomended for 2" and up, think rough country makes them for the 2.5" lift but camber bushings should correct the camber issue just fine for 1"-2".
Also I think its rough country that makes the radius arm drop brackets for the 2" lifts, once again recomended not required.
I installed the skyjacker 2.5" lift springs in the front of my 86 ranger(Same TTB system) and only needed the camber bushings. stock brake lines work fine with the 2.5" lift.
A drop pitman arm is not required, and my stock shocks have enough travel..
Hope that helps.
4.0B2
151
Walls, MS
4.0 v6
drop pitman arm not required... but if your steering is jacked up at the arm and not level, you will need it...
The_Dealer
10
Macon, GA
Duh!
mine with 2" spacers needs a drop pitman bad
Eagle Point OR
FORD
My 86ranger does not need a drop pitman! it rides fine down the road....
The bump steer is the same as stock! (floats like a caddy)
And my Ranger hit trails untill the creek killed it! YOU DO NOT NEED A DROP PITMAN!!!
PetesPonies
25
east coast
Ranger
2.3l
My '84 sits very well now, doesn't droop at all and sits higher than many B2s posted here. Perhaps the springs were different in '84. Anyway, I may go with just a 1" lift in the front. I really don't want to have to modify anything . . too much other work to do on other vehicles :)
4.0B2
151
Walls, MS
4.0 v6
I just said that IF your steering looks all jacked up you'll need a pitman arm. It's possible he will. For some reason different trucks take different lifts different. Idk why... But that's how it seems to work
buzz88
Southeast PA
Bronco II
2.9L
2in lift
Don't quote me on this but after i put my 2in suspension trailmaster lift on my 88 B2, the rear driveshaft went bad I think the angle of the lift caused it, I had a lift with the springs, camber bushings, alignment and add a leaf in the back which ended up coming out later, didn't really need the added leaf.
PetesPonies
25
east coast
Ranger
2.3l
I understand everyone's concerns and they are valued. I'm not looking to offroad and like I said, mine sits well even now. So I think I'm going to lift it about an 1" or 1 1/2" and see if I can get away with no problems.
Area 52
Newport Beach, CA
2.9
A slight lift for my 90 was as follows:
Front:
I installed progressive rate front Explorer coils resulting in a 1.5" lift. The spring rate on these is a tad too lively for my liking though...in hindsight I would probably opt for some super heavy duty (non-progressive) coils and lift it with washers.
Replaced tall sway bar D-bushings with short ones (Energy Suspension 9.5161G-greasable). This realigns the sway bar arms back to almost perpendicular to the axles.
Replaced sway link rubber with poly bushings.
The steering linkage angle is about 2 degrees up towards the pitman which sucked the toe in by 1/16" overall.
Camber on l/f & r/f is -.04 & +.01 degrees (no camber bushing change-out needed). I thought one of the sides was whacked but apparently my method of measuring with a gravity degree gauge was flawed. The alignment shop said toe, camber and caster measurements were perfect.
Rear:
Tuff Country short overload leaf installed in the middle of the spring pack resulting in rear lift of 1.75". May need 2-2.5 degree pinion shims between the spring pack and spring perches.
Bilstein HD shocks and new BFG Long-Trails (235/75/15's) on all 4 corners.
The car sits and tracks down the road perfectly for this old fart. May install some 1.25" wheel spacers on the rear to widen the track and get a beefier rear sway bar to improve cornering stability. This is primarily an on-roader.
Staff online
Today's birthdays
Shran
April Truck of The Month
