What's the best/favorite/worst mod you have ever done
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Best- 4.0 swap
Favorite- M5OD swap
Least- The Rough Country lift. The springs are a little stiff.
gw33gp
Ham Radio Operator
531
Costa Mesa, CA
4.0 SOHC
33"
Best: Bama computer re-program.
Favorite: Gibson single cat back exhaust.
Worst: Buying new 31" street tires a few months before installing 4.56 gears for my 33" off-road tires.
CAD
Greeley, CO
2.9L
best: m50d & 10" clutch from fm145 & 9", power windows and locks from B2 with door vent windows, and halogen replacement headlights with upgrade wiring harness from LMC.
Haven't had a worst yet but I'm sure I will eventually.
B-Lazy
Simi
Best:
Pre cat delete on Y pipe
m5od swap
Bronco II sway bar
Worst:
Bending needle on tach during m50d swap
Flat Toy
13
Dallas
2.9/2.5
Best: Replaced BII rear seat belts with seat belt /shoulder harness.
Replaced door and ignition locks with a set from an explorer to have one key for both
Favorite: LED third brake light from a Chevy Astro Van.
ZMan
MTOTM Winner
406
Medina, Ohio
Ford Rangers
4/4, bagged
Best: Cobra Mustang brakes all around (13" front 11.2" rear)
Worst: Cutting my roof out for the "Superdome" that only lasted 2 days before it flew off and shattered, irreplaceable. Need to get around to making a soft top..
Favorite: Paintjob!
miller time
rockfalls IL
FORD
3.0 duals out the back 4.0
The 4.0 from 3.0 was the 2nd best mod
cp2295
7
Washougal, wa
4.0L swap, 8.8 explorer axle, IFS front end
If you ain't first you're last
I second the 4.0 from the 3.0! Also throttle cable mod cuz it was free. Probably also the explorer rear end!
racsan
4,317
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
Hurst shifter is my favorite mod. Worst mod is bent frame.
chvlfrk
December 2010 STOTM Winner
MTOTM Winner
31
Niota, TN
Ranger XLT 5.0L
5.0L
235/70R15 front / 275/60R15 rear
Green 94 XLT>>>
BEST: 95 Explorer 8.8 swap....
FAVORITE: Narrowing the 8.8 3" and moving springs to under frame for the MEATS......
WORST: Moving firewall back 3" for V8
miller time
rockfalls IL
FORD
Moving the firewall back had to be a pain and a lot of fab work
LIMA BEAN
140
ALASKA
miller time
rockfalls IL
FORD
New worst mod is not having a f ing full size spare tire. But I had no spare at all so dad take the 30" off the wrecked blue ranger to get it home
AllanD
134
East-Central Pennsylvania
1987... sorta
'93 4.0
The best mod? that's kind of a toss up?
One of the following:
1)Mounting my spare tire inside the bed where it is actually accessable
I used a stock dual tank bracket, but I mounted the spare tire behind the wheel tub in the bed, because my "Tool box" is mounted in the front, additionally the 235/75-15 tires I run would not fit in the forward location.
2) the "Factory" sunroof (robbed from 1988 Eddie Bauer Bronco2)
3) converting my truck from 2wd to 4x4
4)While switching from a 2.9 flywheel & Clutch to a 4.0Flywheel and Clutch was "Good" swapping in the rest of the 4.0 and getting rid of the 2.9 entirely was better.
5)Upgrading the Original TK5 trans to a Mazda M5OD-R1 trans.
The fact that I managed to sell the Tk-5 for more than the conversion
cost me was icing on the cake:)
Worst mod? the pop open quarter windows on my supercab.
They never delivered the ventilation I expected, so in essence they were a whole lot of work for no real benefit.
Kirby N.
March Truck of The Month
