Going to hunt down a 302. What else to get?
CajunPwnStar
Lafayette, LA
2.3L
First off, I'm on my Tapatalk app at work and can't get to the tech library to view the detailed write up about this...
Going after work to the local pull-a-part to hunt down a 302 block. Plan is to have it bored and build a 331 stroker for street, not track. Donor will be one of like 5 Expo 5.0s they have there. What else should I snag from it while there?
Elutheros
129
Central Texas
Intake manifold, heads (go GT40 not the p so you will have more header options), throttle cable, FEAD complete, get the return style fuel rails from an earlier Expo V8 if you are not going to use the OBD II stuff, alternator, power steering pump. You may be able to use a double core (HD) radiator from an earlier 4.0 Expo depending on how much HP you are going for. Might think of some other stuff later.
