bluemoon
- Apr 10, 2017
- Reaction score
- 0
- Make / Model
- Ford
- Automatic
I have a 2003 Ranger FX4, Level II. My 4-wheel stopped working. I have eliminated the switch and the control module as the cause and am now focused on the transfer case shift motor.
I removed the motor, took it apart, and was assuming, from what I've read, that the bushing was probably cracked and broken. But, my motor has no bushing. It is quite different inside from the photos I've been able to find. In fact, most of the troubleshooting info I've been able to find is for Rangers that are older than mine.
Can anyone please tell me if the type I have is repairable? Can that nylon piece be replaced? Or does it look bad? I did notice that most of the grease is on one side of the piece and also on one side of the part that connects with it, and I would expect it to be equal on both sides. Also, do any of the other parts look like they have a problem?
I'm assuming that this design is supposed to be an upgrade from the older type that has the bushing? I'd sure like to fix it rather than replace it, if possible.
Thanks for any help!
