Losing Oil Pressure 93 3.0
Rearanger
23
Southeast USA
EVERYTHING in the engine compartment is covered in oil and mud.
Given the lack of maintenance you may find engine sludge, which may explain the noisy lifters.
Angie
368
Vancouver area BC Canada
92 & 83 project
4.0L 302
"I could not figure out an easy way to add the actual oil pressure gauge."
I wish you well on this project. do you have a torque wrench?
makonkey
Engine disassembled
I have gotten the engine out and broken down. Whoever did his transmission job apparently re-installed using an impact. A lot of the bolts were way over torqued and rounded.
This engine has diffidently not been well taken care of. It is sludged bad. The oil pump was extremely obstructed. The entire bottom of the oil pan is full of gunk, as well as most of the engine.
I am worried about the crankshaft. I would prefer to have it reground but I do not want to add another 150-200 to a free job. What would happen if I just replaced the main and rod bearings.
8,370
That one missed a few oil changes.
Mains won't last long that way, bearings are softer metal so you may be able to clean crankshaft up with Crocus cloth, that should remove most of the old bearing material from the journals.
I don't think they would be out of round
Emery Cloth tends to leave grit behind, but if you want to start with that and switch to crocus cloth I think that would be fine.
Not my money of course, and I know it adds up, but.............I would spend the $200 to have crank turned.
JP02XLT
8
Indiana
I dont like the looks of the bearings, wear on the ends & not in the middle is a sign of the crank out of round, and that crank has way too many ridges in it for me, I feel your wasting money on new bearings and such if you dont turn the crank.
You may be money & time ahead, looking for a 3.0, any year from a Taurus, Windstar, Ranger will work using your intake - exhaust and brackets. I paid $250 for a complete motor with less than 14k miles & $75 to ship it, it was in Canada.
I cant see rebuilding a 3.0 when they are dirt cheap, if you look around.
JP02XLT
bucko
JP02XLT
^^^ This, unless you simply want to rebuild an engine. And if you do (want to rebuild) then do it right.
makonkey
I looked for a while online and have not been able to find a good condition engine local for less than 400. I did find a few that could be shipped for around 300. Looking at bearings gaskets and oil pump for around 200. I dropped the crank at a machine shop to see what they think. I will probably go with the refresh rather than used. I would want to clean a used engine anyway. If it was mine and I had more time I would keep looking for a good used engine. I feel like I need to get it finished.
