| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| 4WD Systems Transfer Cases & Locking Hubs. Forum sponsored by The Shiftster |
Thread Tools | Display Modes |
#13 |
Junior Member
Year: mostly 1987 but
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
Used For: Just about everything
Rep Power: 11 ![]() iTrader: (0)
I guess ill bust out the angle guage again.. I doubt its in the rear end though. Maybe a bent pinion flange I'll have check that..
Tweet
#14 | |
Boost Junkie
Year: 94,94,95,01
Make: All 10 are Ford
Model: Ex, Cobra, Ex, Ranger
Engine: 4.0,5.0,4BT,4.0
Class: none
Used For: Going places.
Rep Power: 45 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (3)
Quote:
__________________
'95 Explorer -- EEC-IV SOHC swap. Now getting a "moderately built" 4BT Cummins, ZF, 4406, US Gear OD unit, 13" Cobra brakes, '99 Cobra wheels,.... 4BT swap thread Ranger bed trailer build Scars are just tattoos... with better stories! |
Tweet
#15 | |
Junior Member
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
Quote:
Tweet
#16 |
Boost Junkie
Year: 94,94,95,01
Class: none
Driveline vibrations usually get worse with higher speeds. Its very rare that they come and go within a small rpm window.
__________________
'95 Explorer -- EEC-IV SOHC swap. Now getting a "moderately built" 4BT Cummins, ZF, 4406, US Gear OD unit, 13" Cobra brakes, '99 Cobra wheels,.... 4BT swap thread Ranger bed trailer build Scars are just tattoos... with better stories! Last edited by snoranger; 08-09-2012 at 11:55 PM. |
Tweet
#17 |
Junior Member
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
Well that's awesome leave it to me to have the weird one.. ya it starts around 40 and by 55 its ok.. it's a droning type vib hard to explain. I really haven't driven it much faster than 65.. So we're wanting the pinon angle the same as the second u-joint of the DC? Correct?
Tweet
#18 |
Boost Junkie
Year: 94,94,95,01
Class: none
Basically, you want the single (rear) u-joint to have no angle, and on the double cardan (front) each u-joint will each see half of the total driveshaft angle.
__________________
Tweet
#19 |
Super Moderator
Year: '91, '85, '97
Make: ford
Model: ranger, b-II, f-150
Engine: 4.0,4.0,4.2
Class: 4x4 race, 4x4, 2wd work
Used For: 4x4 race, 4x4,2wd work
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
I had a 9" in a '68 Torino. When I changed in a used set of gears I got the same vibration your talking about. Later down the road, I talked to an [IIRC] instructor at a college that suggested that the ring and pinion were out of phase. It seems that there are certain teeth that will connect in one position but not another and if you happen to get the teeth meshed wrong you will get that drone.
Richard
__________________
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein |
Tweet
#20 |
Junior Member
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
I hear you on that.. but I'll level with you this is the second set of gears I've put in this truck I did the first set and had the same issue.. Soo.. I. got another set and had them professionally installed thinking i did something wrong.. turns out it's exactly the same.. I wondering if the driveline itself is to blame. The thing is I really don't wanna spend a bunch a cash here, ( I already have) this is my daily and I want it to be right..
Tweet
#21 | |
Mall-Rated
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Quote:
As for the vibration, I've had some that come & go at different speeds, I wouldn't put it past a slightly out-of-balance shaft or a bent flange causing such a vibe.
__________________
'90 Bronco II XLT 5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s '94 Ranger XLT 6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s |
Tweet
#22 |
Junior Member
Make: Ford
Model: Ranger
Engine: 2.9
Class: 4x4
It does come and go at different speeds.. I'm wondering if its a u-joint phase issue. Like maybe the drive line wasn't assembled correctly.. Something like this..
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
