99 ranger will not start, replaced starter, ignition switch, neutral safety switch
phonofan
Brighton MI
4.0
I have a 99 ranger 4.0 4x4 that will not start unless I jump the solenoid on the starter. I replaced the starter after I took it in and had it tested and it failed. Truck still wouldnt start so I figured it might have also been the ignition switch, replaced that and no luck. Replaced the ignition safety switch along with it to be sure. I turn the key to the on position and everything works, lights, radio ect but no start. All fuses and relays are good. Running out of ideas, any help would be greatly appreciated.
Earl43P
38
Farmington, Pa
Ford F250 4WD
3.0
I have a schematic from the 2000 EVTM which may clear it up for you.
Send me a PM with your e-mail address and I will send it out.
Basically, you have the 7.5A relay control fuse, the ignition switch, the DTRS (you DID adjust that so the reverse lights come on properly, right?) and the relay coil, then you have the big fuse (50A) the relay contacts, and the YE/LB wire that routes power to the starter to engage the bendix solenoid of the starter.
You already know the big power cable to the starter is good, so it has to be in the relay coil control side of the circuit.
Speed_Trendz
I know this is an old thread but this sounds exactly what my truck is doing. What was the fix ????
low~n~blue
February 2012 STOTM Winner
MTOTM Winner
4
Arizona
FORD
had issues with my truck and it was the battery cables, worth a check.
Staff online
Today's birthdays
Shran
April Truck of The Month
