OkayKafka
- Mar 23, 2016
- Reaction score
- 1
- Location
- Seattle
- Make / Model
- Ford
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- 2.3L Turbo
- Manual
- 2WD / 4WD
- 2WD
This is from my 2.3l turbo engine that is likely (from the block code) from an 1984 SVO. I pulled the head off to do some inspections. The pistons and the cylinder walls are surprisingly clean. From the looks of it I don't have to rebuild the lower end. I've just been trying to before I go farther what the numbers 4 or 5 stamped into the pistons means. I've been looking but can't really find anything that's satisfying.
I know that manufacturers have different sized pistons they use but I'm not sure about Fords numbers and if it's normal to see two sizes in one engine.
I'm hoping that I don't have to do a rebuild on the lower end. What do you guys think?
