dhkonrad's 93 ford ranger
UrbanRedneckKid
17
Cass Co, Missouri
Diagnose it already. Your worried enough about driving that thing. Lol
Sent from my HTCONE using Tapatalk
dhkonrad
2013 Offroad TOTY
2013 Truck of The Year
Auburn California/ Boise Idaho
lol I will. Just need to find a place to wash the engine down.
UrbanRedneckKid
17
Cass Co, Missouri
Soak it down with some foaming engine degreaser, then find a carwash with hot water.
Then run away real fast, cause the EPA is not your friend.
dhkonrad
2013 Offroad TOTY
Haha that made my night.
dhkonrad
2013 Offroad TOTY
I took it for a quick spin just for kicks then popped the hood.
I guess there was too much mud in the engine bay absorbing all the water, so it never dripped to the ground. Hopefully it is just a bad radiator cap or something.
UrbanRedneckKid
17
Cass Co, Missouri
...that shouldn't over flow like that. Even if the cap was bad. There must be air in your cooling system.
Causes...
Head gasket blown
Cracked head
Cracked block
Water pump shaft seal
Previous work not bled correctly
Reservoir over filled when cold
Too much water in coolant/ water boiling
I would make that a big priority to figure out.
dhkonrad
2013 Offroad TOTY
Causes...
Head gasket blown
Cracked head
Cracked block
Coolant should be almost 50%. Or at least it was before I added a bit more water. When I added water its possible I added a touch too much, but not crazy. Ill keep an eye on it, replace the cap, and maybe bleed it? Whats the best way to bleed it? When I drained it last, I believe I refilled it, let it warm up with the cap off, then kept adding water once the t-stat opened.
It would be the pits if it was a head gasket or something cracked since I have almost zero way to fix that on my own...
Edit: If it was a blown head gasket, wouldn't it cause my truck to overheat and fill my radiator with air? Every time I have checked my radiator it was full of water.
Grunizzle
01/2013 OTOTM Winner
U.S. Military - Active
Albuquerque, NM
4.0L V-6
Easy way to bleed out the air is park it on an incline to put your radiator cap at the highest point. Also if you are really concerned about a blown head gasket or air coming into the system you can do the rubber glove check
dhkonrad
2013 Offroad TOTY
Ok, thanks for the tips. Ill probably do one of those or both in the next couple days...
Dugan
12
New Castle, DE
Ford, IH
2.9L, 355 SBC
are you locked up front? If so you shoulda made that hill no prob.
dhkonrad
2013 Offroad TOTY
No its open. I prob could have made it if I hit it harder, but it was my first day of a front driveshaft so I was trying to not break anything in the middle of nowhere
Sent from my SCH-I545 using Tapatalk
dhkonrad
2013 Offroad TOTY
i got spindles today finally. Thanks for the offer though. Sick truck btw, im hella jealous...
Sweet. I just lined up a pair from a friend to get to you, but nm haha.
Thanks man, I appreciate it!
doker
plantation florida
v6 3.0
How did you make your fender flares ? I'm in need of some and I like yours lol . Great looking truck !
dhkonrad
2013 Offroad TOTY
Thanks!
They are actually just garden edging from Home depot. All four cost me about $7.50. I bought a 20' roll, and then just stuffed them up on there and used phillips head sheet metal screws with large heads on them to screw them onto the fender. I got the type of lawn edging that has a lip on the bottom, so I folded that around the lip in the fender, which holds the fender flares in there better. Idk if that makes sense. I can draw a picture or take a picture if you want.
