Air Filter question
mtnrgr
758
California
3.0
2WD / 4WD
2WD
6" Skyjacker, with 1.5" coil spacers, custom radius arms, custom traction bars
31x10.50
Lord God is my guardian
Staying with Ford filters.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
For drop-in paper filters Fram and Purolator are my top two choices for aftermarket.
I slam Fram oil filters up and down all day long. Their air filters are actually really good. Purolators are a close second IMO.
Rearanger
23
Southeast USA
You're looking to balance filtration with air flow. Filters that remove finer dust particles will have reduced flow unless their filter area is increased. As a filter gets dirty it's efficiency to remove dirt actually increases.
Here's a little experiment to understand the thinking.
http://www.bobistheoilguy.com/airfilter/airtest1.htm
Most aftermarket filters probably do a pretty good job.
ratdude747
22
Madison, IN
Engine Type
4.0L
2WD / 4WD
2WD
215/70R15
No issues with the purolator in my 1995 3.0. Fram also looked good. I still use the Ford Motorcraft FL-400S for my oil filter though.
enjr44
9
Renton, WA
02 2X4; 08 FX4
4.0 SOHC
I don't really know why; but, I use Wix filters for everything.
ratdude747
22
Madison, IN
Engine Type
4.0L
2WD / 4WD
2WD
215/70R15
Rearanger
23
Southeast USA
they said Ford still makes air filters for my truck.
Doubt Ford actually makes the filters. Most likely they contract to Wix, Purolator or other. You more than likely paid much more for the same filter at a parts store.
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,814
SW Iowa
Engine Type
V8
5.0
I get tired of that.
A guy at the local Carquest is always spouting that. "Carquest filters are made by Wix" "Carquest oil is made by Valvoline"
Well the Fiesta is made by Ford. So is the new GT. Does that mean they are the same car? No, they are made to different specs.
BTW I run Wix air filters that actually say Wix on them. :icon_thumby:
Rearanger
23
Southeast USA
I get tired of that.No, they are made to different specs.
That would be OK if you knew the "better" or "different" specs that Ford uses. Could you tell us what those specs are?
Why not Ford with the better specs?
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,814
SW Iowa
Engine Type
V8
5.0
Never looked into it. I don't see them marking down the same product that much and letting it fly under someone else's name that directly competes with their name.
I was just saying just because it is made by the same company that doesn't mean it is the same thing.
I could probably buy 3-4 Wix for what the local dealer would want for one. And I don't think the difference in quality would be huge.
I use MC oil filters and oil because they are priced reasonably at wally world.
My truck almost has 140k miles on it running in a filthy environment, intake is always clean and it runs great. I do check them every oil change because I do a lot of running on gravel roads.
Staff online
Today's birthdays
Shran
April Truck of The Month
