VinCecil
- Dec 28, 2015
- Reaction score
- 0
- Make / Model
- Ford
Been trying to figure this out for about a year. Its my daily driver so chances to work on it are slim.
It starts perfectly fine. Idle sounds a little high, but have no rpm gauge so idk.
Acceleration is slow, it hesitates, and upon any medium to heavy gas, it sputters like a wild horse. It violently shakes and occasionally has a small backfire or pop that sounds very faint, but i can definitely feel it jerk.
Problems have been consistant over this year before i made any repairs, but what i have done.
New plugs twice, tried platinum i think, then went back to copper i believe because i read copper ones are better? Idk its been a few months.
All wires look good, but i replaced one cus the inner boot came out and stuck to the plug.
Cleaned maf many times.
Air filter is getting changed next weekend cus i like $10 things that keep it healthy. Its really not bad yet.
Ran seafoam multiple times.
Cleaned iac (gasket is chipped but not to the insides)
Replaced pcv. There was a half inch if gunk around it.
Replaced fuel filter below drivers door.
Did a transmission flush.. wow thats another story.
Only codes im getting are 02 sensor or running lean on both banks.
And it seems if i run my gears further its not as bad, but without a rpm gauge im scared of damage. Also when it is 70 degrees on these florida december mornings, it runs better til it warms up. At least i think im awake enough to tell.
Ive searched on the forums many times and found threads of similar problems, but none that match mine. So any and all help or pointers in appreciated.
