AnnoyedEasy3
- Jun 15, 2013
- Reaction score
- 0
- Make / Model
- Ford
- Automatic
My 90 Bronco 2 2.9L V6 "Stock Engine"
is being annoying posted some thing on other sites and nobody knows the answer.
My truck starts right up and idle's perfect in Park and Neutral.
But when I put it in R/D I can only rev it to 1.7k RPM before is looses fuel pressure?
It wants to stall but it doesn't stall just puts and grumbles real low.
Things I was told to replace and did are:
Fuel Pump
Fuel Filter
Fuel Pressure Regulator
Ignition Coil
Throttle Air Bypass Valve
O2 Sensor
Catalytic Converter
Muffler
Distributor Cap
Cap Ignition Rotor
What else can I change? This Truck is starting to annoy me
Fuel Pump
Fuel Filter
Ignition Coil
O2 Sensor
Catalytic Converter
Muffler
Distributor Cap
Cap Ignition Rotor
