| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here. |
Thread Tools | Display Modes |
#1 |
I can't find the info anymore as to why, but my daughters '93 Ranger has no air flow through the dash vents, when the control panel directs it that way. Yes, it's through the defrost and on the floor, but not vents. What's the reason? I had the info that it's for a "fail" situation, but can't find it anymore. Thanks for the help.
Tweet
#2 |
Lab Rat for V.A. hospital
Year: 1989/1936
Make: Ford
Model: Ranger XLT
Engine: V-8...Carbed/fo-barrel
Class: 2WD Street
Used For: FUN on a daily basis!
Rep Power: 72 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
until someone gives you the right answer...bump the airbox that's under the dash a couple times to see if you can get the air "doors" to unstick......so the air will come out of the dash vents....
__________________
*******My Stupied Build Thred! http://www.therangerstation.com/foru...ad.php?t=30561******* *****All the people who's freedom of speech I fought to defend are now telling me to shut up***** **********The Congress that gave me a Machine Gun to kill as many enemy as possible now wants my Winchester Model 1894 because I have PTSD!********** |
Tweet
#3 |
Year: 2002
Make: Ford
Model: F150 XLT
Engine: 5.4l
Class: 2WD
Rep Power: 20 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
That usually means there's a loss of vacuum. Check under the hood, for a broken line, bad check valve, leaking reservoir, etc. It can be under the dash too but with the engine heat, things dry out there. That's where I've found most leaks.
__________________
Bert |
Tweet
#4 | ||
Tracked and Locked
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9 High Performance
Class: 4x4
Used For: Elevenses
Rep Power: 93 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (13)
93 uses a vac driven mode door. Floor/defrost is the default position, generally caused by a loss of vacuum to the system. Start looking for broken lines.
__________________
Project: Hillbilly Deluxe Project: Amazing Grace Project: 12-Volt Sandwich Quote:
Quote:
HELP REPEAL OBAMACARE Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind. |
Tweet
#5 |
I had been thinking vac line, also. Ones I hadn't replaced, I rechecked. Pulled the dash, as I had to change a bulb anyway, and surprise! It's a broken cable! (I hadn't seen vac lines to the control panel). Then end that was left was not easily movable, so it's stuck somewhere inside further.
Does the other end of the cable go to heater/ac box on firewall in engine compartment? Easy to replace? Thanks for the help! |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
