Sdude2008
- Sep 11, 2007
- Reaction score
- 18
- Location
- Farmington CT
- Make / Model
- Ford
- Engine Type
- 3.0 V6
- Engine Size
- 3.0 Flex
- Manual
- 2WD / 4WD
- 4WD
- Tire Size
- 31x10.5x15
1999 4wd. I'm working on changing my ball joints. half way in I realized I need to take the knuckle/hub off the axle to gain clearance to unhook the knuckle from the old ball joint. I've replaced many axles on other cars and have always been able to clearly see the axle nut once I removed the cover. In this case I have removed the locking hub unit and I can see into the hub where the axle is sticking through but I cannot see any axle nut. What am i doing wrong or what else do I need to do. I've searched and watched videos and they all show the axle nut right there.
Back bolts? ugh
Thanks
Back bolts? ugh
Thanks
