Spindle interchangability
Submakr
Hello,
Will 2002 spindles fit on a 1999 coil front end 2WD? We are trying to correct a negative camber issue. Truck has Fabtech UCA and lift spring and some sort of aftermarket lift spindle we can't ID. Camber adjustment is maxed out in the slot.
Thanks
pjtoledo
2,955
Toledo Ohio
Fords
3.0 2.3
1998 & 2002 2wd coil spindles should be the same.
BEWARE>>>1998+ coil spindles are different than 1998+ torsion bar spindles!! the top hole is smaller in the coil spindles. that means the upper control arm/ball joint is different too.
that being said, what size is the the Fabtec upper control arm ball joint stud? if its the big size it won't fit the stock coil 2wd spindle. I have no idea what the specs are on the Fabtec stuff.
Submakr
The Fabtech ball joint stud is the stock diameter.
