- Oct 31, 2011
- Reaction score
- 0
- Location
- San Antonio TX
- Make / Model
- Ford
- Manual
Hey guys, bought a 97 explorer 2 dr sport (I know, not a ranger) command trac 4wd, 4.0 OHV, 5 speed for CHEAP. Thing is mint but a few minor problems. Ran like crap when I got it, MAF, IAC and TB were filthy so I cleaned them up and its running a lot better. New fuel filter, EGR/DPFE is good, new plugs, wires/coil is good, fuel pressure is at 40 on the rail and injectors are good. Has a slight stumble at idle with ac on after a few minutes of idling (no big deal because a "stumble" is like 760rpm to 730). HORRIBLE gas mileage, decent power, no stumbles at any rpm except idle after a few minutes. No CEL at all, O2's seem to be good. Only mod on vehicle was a previous owner installed K&N filter and box kit. 192k miles. Runs at about 180-185 degrees and doesn't take long to get there, never seen it go over 189 on scan tool. Mostly new charging system so no voltage problems, no noticeable vacuum leaks. Idle smells slightly rich but not bad. Getting 7-9 mpg around town driving it easy. No visible smoke from exhaust and FPR has been replaced.
