01 V-8 Power steeing hose question
artsinnashville
nashville
5.0
donor is a 97 V_8 5.0
the donor high pressure hose is threaded on the rack end
the rack on the 01 2wd ranger is the bolt on press fit.
is there a known hybrid hose for this application.
or do I need to have s custom hose made??
the donor mountaineer is gone so no hopes of using the rack from the donor vehicle.
thanks
:beer:
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
Interesting. Have you tried looking up the '01 V8 hose? I'm curious if it was bolt on or press fit. My '99 Ranger was threaded just like the '99 Explorer donor.
artsinnashville
nashville
5.0
all the images I see on line are threaded on both ends
I have a custom hose shop close to the house if all else fails
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
I found pictures of the hose you've got on your 2001. First I'd realized that it had changed over the years. No chance of your current hose fitting?
artsinnashville
nashville
5.0
the length is perfect , just the connection at the rack has changed
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
I meant use your existing Ranger hose with the Explorer power steering pump - no chance of that happening?
artsinnashville
nashville
5.0
I am going to try that , I have a feeling it may be just an inch or 2 too short , will let you know if it ever stops raining here.
win
12
5.0
Use a 3/8" hydraulic hose compression coupling to marry the very end of the Ranger hose assembly to the Expo 5.0 assembly.
A cheap brass compression union might take the pressure but a steel hydraulic union will get the job done.
V8 Level II
Dec 2008 STOTM Winner, 2008 Truck Of The Year
MTOTM Winner
RBV's on Boost
4
Michigan
Supercharged 5.0L
This is exactly what I did on my 2003. Same situation as 2001 Ranger.
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,774
SW Iowa
Engine Type
V8
5.0
Sounds like something that needs submitted to the tech library if you have a camera and a little bit of free time :icon_thumby:
artsinnashville
nashville
5.0
once I have the hose made I will do so
Staff online
Members online
Today's birthdays
Shran
April Truck of The Month
