cstarbard
- Aug 10, 2017
- Reaction score
- 4
- Age
- 30
- Location
- Oakham, MA
- Make / Model
- Ford
- Engine Size
- 2.3
- Manual
- My credo
- It do like it be
Hey all-
I'm doing all the front axle and front end seals in two TTB trucks, a 96 and a 97. Both have the D28/35 hybrid axle. I'm having a real hard time finding some of these seals for the wheel end of the assembly. Hoping some of you can share part numbers for the seals I need, as described below.
There seems to be 4 seals in total at each wheel end, two of which relate to the rotor and two of which relate to the spindle.
1. There is a seal pressed into inner side of the rotor that covers the inner wheel bearing- that one I have been able to find quite easily, no part number needed
2. There is a seal that slips onto the spindle, that goes against the rotor's inner wheel bearing seal. I can not find a replacement seal for this one. I have one intact which has no manufacturer name on it, but has the numbers "46218" and "2RB 63-8" and "2"
3. Next seal is the seal that presses onto the outermost piece of the axle shaft assemblies (I.e., the short shaft that goes through spindle into locking hub) to seal where the axle shaft meets the inner side of the spindle. I have found this seal (National 710453)
4. Lastly, there is a pesky plastic washer-like seal that goes between the 710453 seal and the backside of the hub spindle. I also cannot find a replacement this seal to save my life lol.
If anyone has found replacements for these and can give me part numbers or even a diagram showing the original Ford part numbers either would be hugely appreciated! Thanks in advance.
