cp2295
- Jul 25, 2013
- Reaction score
- 7
- Location
- Washougal, wa
- Make / Model
- Ford
- Engine Size
- 4.0L swap, 8.8 explorer axle, IFS front end
- My credo
- If you ain't first you're last
Anybody ever made a bent shifter for an M5OD like the fm145 has? Swapping a 4.0 and an M5OD into the b2 and noticed that the shifter sits a couple inches forward, and I’ll have to notch the body a little to accept the shift plate. I have a feeling I’m going to dislike how far forward the shifter is gonna sit (especially since it’s straight for the M5OD). Wondering if could just chop both shifters up and weld the fm145 upper shifter portion to the M5OD base.
Also nobody has come across any issue with the t case shifter position correct? I have the shifter/bracketry from the donor Explorer.
