gen 1 frame gen 2 frame.are they the same?
svtcards
137
Lyman maine
ford
Engine Type
V8
302
2WD / 4WD
2WD
Total Drop
3'' front 4''back
I want to know if the 1983-88 frames are the same as the 89-92 frames.i know the cab doors and bed are interchangeable.but how about the front.i also know the bumpers are a tad different.i want to bolt up a 1991 4.0 to my 1987 ranger.want to know if it'll bolt up without and modifications?tried to search forum couldn't find an answer to my particular question.
adsm08
Senior Master Grease Monkey
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
The 4.0 is a big 2.9. It drops right in. Fuel lines and wiring are the biggest parts of the job.
Shran
Junk Collector
Solid Axle Swap
Truck of Month
4,789
Rapid City SD
Engine Type
V8
5.0
Frames are slightly different - 2nd gen front bumper mounts are way different. 2nd gen front clip will NOT bolt onto gen 1 core support or vise versa. Virtually nothing is bolt on, plug and play stuff. You will have at least minor modifications with anything you are wanting to do.
svtcards
137
Lyman maine
ford
Engine Type
V8
302
2WD / 4WD
2WD
Total Drop
3'' front 4''back
1987 2.3l to a 1991 4.0l swap
I was told I didn't have to do anything to fuel system if I put a 4.0 efi swap into my 1987 2.3l efi replacement.so will a 1991 4.0l and its mounts bolt right up to my 1987 with minimal issues.How much of a pain is the wiring from 1991 to a 1987 ranger?
97RangerXLT
Forum Staff Member
3,924
Fishers, IN
Engine Type
4.0
2WD / 4WD
2"
31"
Do you have the transmission that goes with that 4.0? and the radiator? those will not transfer over from your 4 banger...
AJ
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
The engine will bolt in just fine. The 4.0 used particular fuel lines, so the connections and placement may not be direct fit. I know on both my 87 and 88 that I 4.0 swapped I had to change the barrels and shorten some stuff to make it all line up nice.
If you had a 2.3L you need to replace the trans and the radiator too.
The wiring isn't hard, but it can be time consuming to get it all correct and pretty. I can drop a 4.0 into a truck, splice three wires, and make it run in an hour. If I do it to make it look pretty and get everything done cleanly I will be at it for a month or more.
svtcards
137
Lyman maine
ford
Engine Type
V8
302
2WD / 4WD
2WD
Total Drop
3'' front 4''back
AJ
I have the complete 1991 ranger with the 4.0l.will crossmember line right up to the auto trans.my 4banger had a 5sp in at the moment.not sure about that yet?
svtcards
137
Lyman maine
ford
Engine Type
V8
302
2WD / 4WD
2WD
Total Drop
3'' front 4''back
besides the fuel lines the fuel system itself should be fine right?i think they both have in the tank fuel pump.and there both efi.so the pressure should be ok to I hope.where did u find the wiring diagram that should which wires to splice to each harness?
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,771
SW Iowa
Engine Type
V8
5.0
It is late enough there is a good chance the trans are the same length. You need to find out what trans you have for sure first though.
adsm08
Ford Technician
3,613
Dillsburg PA
Engine Type
4.0
2WD / 4WD
31X10.50X15
An 87 5-speed is shorter than the A4LD. 88 started the long manual transmissions. The cross-member ears will need to be relocated, the good news is that the holes are already there. You just have to grind the rivets out and bolt the ears up in the rear set of holes.
Side note, the front hole for the rear set is the same as the bottom rear for the forward set.
I spent a few years at car shows and on Amazon and ebay rounding up factory wiring manuals and then I sat down and spent a month tracing wires, tracing diagrams, and building harnesses. Then I had a few gremlins to track down once I got it all installed.
Every swap is different, different donors, different recipients, different options. It is usually the wiring that is the worst.
Your 87 has a dual pump fuel system, but it will provide enough flow and pressure for a 4.0. It is actually capable of more than you need.
Be ware of the wiring. The EDIS module is not part of the harness, it is a separate piece that plugs into the harness, and the plug and most of the wiring for it is part of the headlight sub-harness. The headlight harness has to be changed, but the plugs on it are wrong for your bulbs, so the plugs need changed out.
It just one of those things, people can steer you in the right direction, help you figure out the broad strokes of what needs to be done, but you kind of have to figure out the details for yourself.
svtcards
137
Lyman maine
ford
Engine Type
V8
302
2WD / 4WD
2WD
Total Drop
3'' front 4''back
are the k members the same on the 91 to my 87.if so i should be able to use the 4.0l motor mounts and everything hope?
Staff online
Today's birthdays
Shran
April Truck of The Month
