Frankenford
11
Washingrad
2.3
oh hell no
nope
15s with moon eye flats.
Rev On The Red Line
My $125 86 Ranger continues to amaze.
It seems the 1977 intake, carb, and distributor, are not the only frankinford parts in here.
The cast factory header is a post 92 item. Heck the entire motor might be newer. Its all well rusted together.
By bottle feeding it, It runs like a sewing machine. It seems the fuel pump took a dump. I crawl under there, and what do I see? An inline Mr Gasket 4-7lb fuel pump.
So Bubba just stuffed another fuel pump up stream of the OEM tank pump.
Is this a common practice? :icon_surprised:
bobbywalter
Ugly Truck of Month
4,667
woodhaven mi
FORD mostly
BIGGER
sawzall?
yeah....i know what frankenfords can do for a guy.
Rangerx2
27
Pennsylvania
3.7 V6
Always question authority
We all know that the old 2.3 Lima motor went through several generations. However getting parts of one generation to work with those of another; well that takes true redneck genius there!;missingteeth;
Only if you are dumb.
Mike benfielf
Nc
Ford ranger
I've learned all to well with my ranger what bubba and the backhill gang will rig up on a truck
Mike benfielf
Nc
Ford ranger
Exhaust hangers made of coat hangers fuel filter bypassed with plumbing pipe missing push rods and a load of duct tape instead of proper wire connections
Mike benfielf
Nc
Ford ranger
Atv Instead of gaskets too
19Walt93
4,410
Canaan,NH
351
3"
235/55R16
When the 3.8 came out in 82 the only gaskets it used were head gaskets, everything else was RTV. And they leaked everywhere until gaskets came out. It wasn't "rednecks" that we were calling the engineers. If a redneck did something it might look a little crude but I suspect it would work.
Mike benfielf
Nc
Ford ranger
Not saying redneck but on my 92 3.0 the vavlecover gaskets are made to go into the vavlecover and the people I got it form just globed at on it and slapped it on oil was pouring out that what I was referring to with the ATV comment red necks would've did better than that
falcon61
Weird! Tank solution.how can I explain my creations? Haywired is great for exhaust.I gots 13 crimps on my rear hydraulic line rot. And a splicedout abs solinoid.
Kirby N.
March Truck of The Month
