Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 06-27-2012, 01:31 AM   #1
Bronco289
Year: 1989
Make: Ford
Model: Bronco2
Engine: 2.9 L
Class: 2WD Street
Used For: Daily Driver
Bronco289 is on a distinguished road
Default Fuel pump question
Hi all, I am brand new here. When I check the voltage for the fuel pump on my 1989 B2 stock 2.9L I see 12.05 volts for about 3 seconds, and then it reads 6.77 volts. This is right on the connector that plugs in on the tank. The connector is unplugged from the fuel pump, and I'm not cranking the engine. Is the 6.77 volt reading normal? Any info would be appreciated.
Bronco289 is offline   Reply With Quote
Old 06-27-2012, 07:57 PM   #2
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: What engine?
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
That is normal to high.
Fuel system functions like this:
Key on, computer commands the pump on for 3 to 5 seconds to prime and then shuts them off. After the priming the pump is run off of the pip signal for the ignition system. That way if the engine stalls due to lack of fuel (such as a ruptured fuel line) the fuel pump will shut off.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Mark_88 View Post
Question: "What year is your truck"?
My Answer: "What part"?
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is offline   Reply With Quote
Old 06-27-2012, 10:52 PM   #3
Bronco289
Year: 1989
Make: Ford
Model: Bronco2
Engine: 2.9 L
Class: 2WD Street
Default
Thank you for the information adsm08 it really helped. I am nearly to the point of gassing the B2 up and seeing if it will fire up.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
