97 trans/t-case in 94 truck
DRanger024
482
Dale, WI
Solid Axle Swap 4x4
6-7” front maybe 3” rear
33x12.50-15
Will the speedometer cable work in the vss port on the t-case housing? I believe they use the same gears don’t they?
Thanks, Rick.
8,369
Yes, same setup on transfer cases up to 1997, same Drive worm gear, driven gear is the one you change to match ratio and tire size to 8,000ppm VSS or speedometer cable
DRanger024
482
Dale, WI
Solid Axle Swap 4x4
33x12.50-15
Thanks Ron!
