Replacing Engine in '92 with '01, have a couple questions
Ranger305
23
Tennessee
3.0 Vulcan
The engine in my trusty 92 w/3.0 lost a head gasket or cracked a head at 255k, so I decided to rip and replace. I now have a replacement on the stand in my garage from an 01 Taurus. I have replaced the head gaskets, timing cover gasket, crank seal, valve seals, and rear main seal. I plan to use the ignition, fuel system, balancer, front accessories, and flywheel from the 92 to make it as plug and play as possible. Also plan to use the oil pan and pump from the Taurus. I'm dropping on a new water pump, pilot bearing, plugs, and maybe clutch.
Questions 1: I think I can just pull the old cam position sensor and drop in my dizzy? Anything I need to do about the oil pump rod?
Question 2: The Taurus pan doesn't have the bung for the oil level sensor. Do most people just clip the sensor and move on, or?
Question 3: The old engine has the one piece upper intake/tb. Should I look at swapping the composite one that came on the donor engine? I have the throttle cable from the Taurus and everything out to the TB.
Question 4: Can I replace the exhaust bolts with standard 8mmx1.25 bolts? Do they need to be grade 5 or 8?
Question 5: Anything I'm missing?
Thanks. I'm sure I'll have a couple more as I go. Old engine is out, so I'm part way there.
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
645
Central Indiana
3.0
The lower intake manifold will need to be replaced with your Ranger part.
Don't think the Taurus upper intake will work. I've seen composite intake swaps before, but they were always Ranger pieces instead of Taurus parts.
As it sits, the throttle body would be on the passenger side, and pointing toward the firewall. If you rotated it 180 degrees to get the throttle body closer to the stock Ranger location, I think the ports from upper to lower and/or mounting holes would be out of alignment. Giving the Ranger pieces a nice port/polish job might be a better use of your time and give you better gains.
I used the Taurus oil pan on my swap without any issues, but my truck is a 2wd, 98+, so you have a much different front suspension and your clearances will be different. Most guys just swap to the Ranger parts to be safe.
Ranger305
23
Tennessee
3.0 Vulcan
Mine is 2wd as well, but due to the sensor issue and the pan gasket leaks that are so common, maybe I should get a gasket and swap the pans and see if the pickup tunes can be swapped?
ericbphoto
Overlander in development
TRS Event Staff
GMRS Radio License
16,530
Wellford, SC
Engine Type
3.0 V6
3.0L
2WD / 4WD
6"
35"
In theory, theory and practice are the same. In practice, they are different.
Your most common metric hardware grades are 8.8 and 12.9, with 12.9 being the stronger bolts.
If it were me, I would order a set bolts that are designed for your engine/manifold. That way, you should get the proper grade and proper length without having to guess.
ratdude747
22
Madison, IN
Engine Type
4.0L
2WD / 4WD
2WD
215/70R15
You will need to swap oil pans and pumps. The taurus pan uses a different pickup tube (longer) and the tubes are welded to the pump. I know this because I was accidentally sent a taurus one once. The TIB/TTB suspension isn't taurus-pan friendly. Also know that this changes the oil capacity from 5.5Qt to 4.5Qt, like your old one.
Ranger305
23
Tennessee
3.0 Vulcan
Thanks for the info so far. I don't think anyone sells a bolt kit, at least not that I've found. For the pan, that stinks, was really hoping not to have to swap them, but sounds like that is a necessity.
Staff online
Shran
April Truck of The Month
