Serving Ford Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Forums Info - Technical Info - Other TRS News Photo Galleries Shirts & Decals Parts Store Classifieds
Go Back   The Ranger Station Forums > Engine & Transmission Forums > V6 Forums > 2.9 Liter Forum
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 08-08-2012, 04:03 PM   #1
catdaddyo
Year: 1988
Make: Ford
Model: Ranger
catdaddyo is on a distinguished road
Default At a loss
1988 Ford Ranger 2.9 V6 4X4 5 speed. Died as if out of fuel. Started checking, replaced both fuel pumps, fuel filters, distributer cap, rotor button, plug wires, took ICM to auto parts and had tested, 3 tests all showed ok.
Engine will start, run a couple seconds, then die, continued cranking it sounds as if it is trying to start, but won't. Let sit for several minutes, starts, runs a couple of seconds, dies. Having someone crank while spraying fuel in the intake, it runs perfect, stop spraying fuel, it dies. Is something cutting off the injectors? Since it starts and runs for a couple seconds, it sounds as if injectors are working at first. Also, if you pump accelerator rapidly, it will barely run as long as you keep it up. Somethings crazy here, either the truck or me! Please help.
catdaddyo is offline   Reply With Quote
Old 08-08-2012, 05:11 PM   #2
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9 High Performance
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Check fuel pressure. I know you replaced the pumps, but that doesn't mean there isn't a pressure issue.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Raj
What you need is cheat codes, motor skills, and a magic genie who grants wishes to little boys who suck at Mario Kart
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is offline   Reply With Quote
Old 08-08-2012, 06:27 PM   #3
catdaddyo
Year: 1988
Make: Ford
Model: Ranger
Default At a loss
I forgot to put that on here. Fuel pressure at the shrader valve on the fuel rail is 42 psi with switch on and also while cranking. Thanks.
Old 08-08-2012, 06:41 PM   #4
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Used For: Elevenses
Default
Are the cats present?
__________________
Old 08-09-2012, 09:11 AM   #5
catdaddyo
Year: 1988
Make: Ford
Model: Ranger
Default
Yes.
Old 08-09-2012, 09:25 AM   #6
catdaddyo
Year: 1988
Make: Ford
Model: Ranger
Default
I read where the TPS should read 1 ohm with throttle at idle, and gradually rise to 4 ohms wide open. I tested the TPS with ohm meter and it is reversed. At idle position with throttle butterfly closed it read almost 4 ohms, and wide open it went to 1 ohm. Would this be shutting down the injectors. I think I saw where it would do that if it sensed wide open throttle. Is this info correct? Thanks.
Old 08-09-2012, 10:45 AM   #7
RustedRanger
RustedRanger's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9L
Class: 4x4
Used For: Everyday driver
RustedRanger will become famous soon enough
Default
The TPS doesn't go by ohms but by volts...I'm thinking 1.0 volt is max. If you already didn't read how to set it in the Tech section.
RustedRanger is offline   Reply With Quote
Old 08-09-2012, 07:26 PM   #8
a31ford
Electronics GURU
a31ford's Avatar
Year: 1988
Make: Ford
Model: Ranger XLT (Custom Frame) With a 3" body lift
Engine: 2.9
Class: 4X4
Used For: Working on "Breakout Box for ECM's"
a31ford is a name known to alla31ford is a name known to alla31ford is a name known to alla31ford is a name known to alla31ford is a name known to alla31ford is a name known to all
Default
TFI and/or Hall effect sensor in the distributor ?
TFI's generally go bad in a heat situation, BUT, thee are other failure modes for them as well.
Have you verified spark ?
Greg
a31ford is offline   Reply With Quote
Old 08-09-2012, 07:32 PM   #9
catdaddyo
Year: 1988
Make: Ford
Model: Ranger
Default
Yes, it has spark. The engine will run fine if you spray fuel in the intake. I'm thinking something is cutting out the injectors, because it will start, run a few seconds, then die, and not start. If you wait five minutes, it will start and run again for a few seconds. This will happen as many times as you want to try it. I'm suspecting the TPS, but I don't know if a bad TPS will shut off the injectors. I need this info.Thanks.
Old 08-10-2012, 12:35 PM   #10
lchappyjr
Junior Member
lchappyjr's Avatar
Year: 1987
Make: ford
Model: bronco II
Engine: 4.0
Class: 4x4
Used For: daily driver
lchappyjr is on a distinguished road
Default
would the inertia switch have anything to do with it?
__________________
You Cant Fix Stupid
Larry Chapman
lchappyjr is offline   Reply With Quote
Old 08-10-2012, 01:00 PM   #11
catdaddyo
Year: 1988
Make: Ford
Model: Ranger
Default
I don't think so, as I checked the pressure at the schrader valve on the fuel rail and it maintains 42 psi while cranking, so it wouldn't have pressure if the inertia switch cut off power to the pumps. The schrader valve is also between the fuel pressure regulator and the injectors, so it shouldn't be at fault. I'm still suspecting the TPS, but I have spent so much already trying parts, that I do not want to shell out $35. to 50. dollars more without knowing what the culprit is. Thanks for your response.
Old 08-15-2012, 01:47 PM   #12
catdaddyo
Year: 1988
Make: Ford
Model: Ranger
Default
Quote:
I finally found the culprit! The map sensor was bad and shutting off the injectors. I did a google search this morning and found someone who suggested unplugging the map electrical connection and see if it would run. I unplugged it, it started right up and I drove it around some to make sure it would run. It does. Thanks to everyone for you efforts, just note this for future reference.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
