1.8TTony
- Jan 5, 2017
- Reaction score
- 0
- Make / Model
- Ford
- Automatic
1994
4.0 v6 engine
Automatic transmission
4x4
Ok, so I pulled the motor out so I can replace all the freeze plugs. I get them all replaced without any problems. I installed the engine....no problems.
I fill the coolant system with water and test for leaks......no leaks, so I drain the water and refill with coolant/antifreeze. I check all the electrical connections and vacuum lines. Everything is good to go. I connect the battery and fire up the engine. It ran fine for 10 seconds and then dies.......hasn't fired up since. The engine spins as if there is no compression.
Things I have done:
Checked for spark....have good spark.
Tested fuel pressure on the rail......have good pressure.
Used a noid light to test fuel injectors for pulse....have good pulse.
Pulled valve covers to see if valves are moving.......have good movement.
Compression test shows good compression.
Pulled all spark plugs and they all had raw fuel on them.....dried them and reinstalled
Set the engine at Top Dead Center pulled cam synchro to inspect for damage......found no damage...rotated the engine 26 degrees past TDC and reinstalled the synchro with open end of the reluctor arc facing towards the drivers side. With the synchro fully seated, the trailing edge of the arc is lined up with the long hash mark on the top of the synchro. This synchro is the type with a sight glass on the top so it can be eyeballed and installed correctly without the special alignment tool that the non sight glass style needs for installation.
Am I missing something here. This is driving me crazy. I suspect that the problem has something to do with the cam synchro.....not the cam shaft position sensor, but the synchro itself. The synchro......from my understanding, is used to adjust length of fuel injector pulse........???!!!
Any ideas would be greatly appreciated.
Thank you.
4.0 v6 engine
4x4
Things I have done:
Thank you.
