TheRangerStation.com  SM
Serving Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Resources Tech Library Magazine Video Gallery Truck Gallery Shirts & Decals Parts
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 10-25-2009, 11:34 PM   #1
DustyClark87
DustyClark87's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9
Class: 4x4
Used For: DD and weekend offroader
DustyClark87 is on a distinguished road
Send a message via AIM to DustyClark87
Default question bout lifting and putting bigger sized tires on a Bronco 2
I have a pretty much all stock '89 Bronco 2, want to get a 3 or 4 inch body lift first of all and then I was wondering how big of tires I could get without rubbing issues? I know I could probably get 31's on but would 32's be pushing it? I dont take it hardcore off roading or anything, just a daily driver occasionally take it on a few trails. Any help would be greatly appreciated!
Dusty
DustyClark87 is offline   Reply With Quote
Old 10-25-2009, 11:38 PM   #2
85DANGERanger
85DANGERanger's Avatar
Year: 1989
Make: Ford
Model: bronco II
Engine: 2.9
Class: 4x4
Used For: intertainment
85DANGERanger is on a distinguished road
Default
31's would be good 32's might be a little tight.
__________________
1989 Bronco II, 4x4, 2in. body lift, 2.9 with crane cam, MSD igintion chip, air/fuel ratio chip, centerforce clutch, ARP bolts in motor.
85DANGERanger is offline   Reply With Quote
Old 10-25-2009, 11:40 PM   #3
85DANGERanger
Year: 1989
Make: Ford
Model: bronco II
Engine: 2.9
Class: 4x4
Default
and honestly, i wouldnt go any bigger then 33's on are weak d28 front axles, they break pretty easy.
__________________
Old 10-25-2009, 11:46 PM   #4
DustyClark87
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9
Class: 4x4
Default
Quote:
yeah 32x10.50's were all the bigger i wanted to go, i wasnt gonna try 33's, dont wanna do any fender trimming though
Old 10-26-2009, 03:12 PM   #5
Bronco_Chuck
Premium Member
Bronco_Chuck's Avatar
Year: 84, 86 & 89
Make: Ford
Model: Bronco 2's
Engine: 2.8 & 2.9
Class: 4x4 & 2WD
Used For: Holding down the drive way/ DD
Bronco_Chuck is on a distinguished road
Default
i personaly run 31x10.5's with a 3" BL and some finder trimming but the trimming is due to the springs being flat. i ran 33x12.5's on my 86 with a 3" BL but i had to trim the fenders on it because they would rub on the very bottem corners of the fenders when turning. so depending on the condition of your springs and the width of the tires along with the back spacing of the wheels it could work out. and fyi ive never had any troubles with the d28 when running the 33's, i did manage to blow up my 7.5 however.
Bronco_Chuck is offline   Reply With Quote
Old 10-26-2009, 06:40 PM   #6
dangerrangerstx
dangerrangerstx's Avatar
Year: 1987
Make: ford
Model: ranger stx
dangerrangerstx is on a distinguished road
Default
there is no such thing as a 4 in body lift unless u ghetto fab one i had a 3 in body lift on my ranger alot of bad trouble came with . just get a lift or sas it
__________________
Ummm your post is hard to read & understand, made my brain hurt ! Would you consider editing it ?
92 ford explorer sas leaf front,d44/d60
38s tsl, drive flanges, 5 ton steering, gutted inteerior
dangerrangerstx is offline   Reply With Quote
Old 10-27-2009, 01:16 AM   #7
jims89broncoII
Premium Member
jims89broncoII's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9
Class: 4x4
Used For: everything. its a B2!!
jims89broncoII is on a distinguished road
Default
you should be fine to run 32's with a 3" body lift. just be sure to get everything tight. then re check/tighten everything after putting some miles on it.
what size wheels are you going to run? what kind of back spacing. that will all depend on if you have to do some trimming to? whats your gear ratio?
jims89broncoII is offline   Reply With Quote
Old 11-02-2009, 10:17 PM   #8
DustyClark87
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9
Class: 4x4
Default
I have 235's on it now, will the 31's make a huge difference in MPG you think?
Old 11-03-2009, 12:49 AM   #9
jims89broncoII
Premium Member
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9
Class: 4x4
Default
not a huge difference but you could probably tell a little. whats your gear ratio?
Old 11-03-2009, 08:00 PM   #10
DustyClark87
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9
Class: 4x4
Default
Quote:
im gonna be honest and sound like i retard but I have no idea.. its a dog in 5th gear tho but thats probably any 2.9 B2, huh? lol
Old 11-03-2009, 08:32 PM   #11
Deamers87ford
Deamers87ford's Avatar
Year: 1990
Make: Ford
Model: Ranger STX
Engine: 2.9
Class: 4x4
Deamers87ford is on a distinguished road
Send a message via AIM to Deamers87ford
Default
where is shade gap pa im from lancaster pa
Deamers87ford is offline   Reply With Quote
Old 11-03-2009, 09:32 PM   #12
DustyClark87
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9
Class: 4x4
Default
Quote:
Its directly west 2 hours, Harrisburg is about exactly in the middle. Kinda close to the Altoona/State College area only closer.
Old 11-03-2009, 10:15 PM   #13
crawlin91
March 2009 OTOTM Winner
crawlin91's Avatar
Year: 1991 1984
Make: Ford
Model: Ranger BII
Engine: 2.9, 4.0
Class: 4x4
Used For: running stuff over
crawlin91 is on a distinguished road
Default
look in the tech library there is a chart there that will help you to identify what ratio is in your axles.
crawlin91 is offline   Reply With Quote
Old 11-03-2009, 10:29 PM   #14
bronchoII
Junior Member
bronchoII's Avatar
Year: 1990
Make: ford
Model: bronco II
Class: 4x4 extreme
bronchoII is on a distinguished road
Default
32's should work fine depending on the rim width and backspacing
bronchoII is offline   Reply With Quote
Reply
Bookmarks
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
will i lose power by lifting my 2.3l ranger and putting on 31in. tires blindguy315 4-Cylinder (2000 & Older) 6 03-17-2008 09:49 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1999 - 2010 The Ranger Station - James Oaks Enterprises LLC - All Rights Reserved
'The Ranger Station' and it's logo are Service Marks of The Ranger Station owned by James Oaks Enterprises LLC.
Legal Notice
