Finally! Post pics of your Diesel Ranger
jesselee20040
Hobbs, NM
2.9 about to swap in 2.3 turbo diesel
Looks super clean, I have a ranger with the 4d55 and a dodge d50 with a 4d55. Both of which the bodies are not good so I have been contemplating pulling the one out of the ranger and putting it in my bronco II and then pulling the d50 motor to keep as a spare..
coyotefiveoh
2.3 Diesel
whats the 4d55 out of?
Well its a mistubishi diesel.... but they came factory in the 85-87 rangers. Alot of things actually use these engines, like the mighty max and dodge D50.... Some pajeros and other mitsu stuff uses them too, although alot of them have the 4d56 which is a stoked version(2.5 instead of 2.3) of the 4d55 but rollerized and stroked. Common upgrade for the 4d55 is to swap a 4d56 head which i plan on doing soon as it flows better than the 4d55 head.
It may "look" clean from the pictures, but im only showcasing the good lol. Floor pans are not very good, pass side box around the wheel well is shot, frame is starting to rust where the struts/shocks are bolted up on both sides, bottom of the doors are shot.... other than that, its pretty good and super reliable and great on fuel! Rockers and cab corners are all in good shape though.
A 4d55 bronco would be sweet! Do it!
coyotefiveoh
2.3 Diesel
so no one else has a diesel ranger they wont to post pics and info!? come on, must be someone!
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
I think it will take a little while for them to come out of the woodwork.
bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
TRS Banner 2012-2015
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
it is easier to fix and understand than "her"
summer, "trail recovery mode"....
usually i run a military type tire on it. i dont have any current pics of it around.....
it runs on a frightening array of fuel. old diesels......easy to feed oils.:D
bobbywalter
TRS Technical Staff
TRS Event Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
these are nice, i got this to add to my new system, it has the good long stroke primer pump and 2 mic filter. they make priming the system a breeze. worth the time to incorporate.
coyotefiveoh
2.3 Diesel
nice build what engine is in that beast?? What exactly does the cat primer pump help with/do?? :S Somewhat new to diesel as this is my first.
bobbywalter
TRS Technical Staff
TRS Event Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
currently it has a 6.5.
the cat setup makes priming the fuel system cake. the super high efficiency filtration will be needed with one of my secondary fuel systems.
i use alternate fuels regularly and use several different fuel vessels/tanks.
PerkinsRanger
I just picked up a 83 with the 2.2 Perkins. Pulled the head and its off to the machine shop for everything but the kitchen sink. I'll post a picture once I figure out how to do so.
Ldr01rl
12
Wisconsin
Engine Type
2.9 V6
2.2L
2WD / 4WD
Respect...
joec
Stroudsburg, Pa
I cannot post pics because I already have them posted in my thread "My new 1983 Ranger diesel". You can check them out there.
bobbywalter
TRS Technical Staff
TRS Event Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
should be able to copy addy...definitely a nice rig.
Members online
Today's birthdays
Shran
April Truck of The Month
