Rearanger
- Feb 4, 2008
- Reaction score
- 23
- Location
- Southeast USA
- Make / Model
- Ford
Still looking into possible cause of dropping mpg from my other thread. I thought I'd see if there were any external fuel leaks in the system as oil analysis showed no fuel in oil. Yes, I could just run the engine and crawl underneath and roll around, but I referenced the FSM and found how to perform the tests.
Both tests (fuel pressure and fuel pressure leak down) do not specify to start the vehicle or do key on. Instead the manual says to - "Access the Output Test Mode". This is a mode activated by a scan tool which runs the fuel pump for about 8 seconds. Not sure why the tests are performed this way. Don't know why just a key on would not activate the pump, unless the run position activates a relay and key on does not start pump.
Any techs out there who can clue me in?
