- Mar 6, 2010
- Harrisburg, PA
- Manual
Dropped the trans to install a freeze plug in the head. Replaced slave while it was down. Now I can't get the line back in the new slave. 94 4x4 5speed 3.0. The fluid line fitting isorange and the coupling on the old slave was also orange and coupled with tiny fingers. The new slave has a larger plastic sleeve and use a clip to hold the connection in. I tried both white plastic sleeves, new larger and old smaller. The way the connection sticks through the trans, I can't get to the clip except to remove it. I can get it in part way, but it doesn't click, starts to leak and pulls back out. The new slave is a Technovation from Advance Auto. The old slave is a Dorman I think.
