Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 03-01-2008, 02:25 PM   #11
Dave R
RBV Technical Advisor
Vehicle Year: 1953
Vehicle Make: Kaiser
Vehicle Model: Chief
Dave R is on a distinguished road
Default
Quote:
Originally Posted by Hardwareman View Post
I'm thinking of changing out the rear main seal right before dropping the engine in because I need to take the engine off the stand anyways to gain access to it. It should only take a couple minutes. What do you think?
Sounds fine.
Dave R is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 03-01-2008, 06:17 PM   #12
LearjetMinako
LearjetMinako's Avatar
Vehicle Year: 1996
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Work & Daily Driver
LearjetMinako has a spectacular aura aboutLearjetMinako has a spectacular aura aboutLearjetMinako has a spectacular aura about
Default
Just did mine today. Doing the seal was almost the easiest the part. Getting to it, a royal pain. I removed the front seal by using the sheet metal screw technique. Putting the new one one proved to be a bit more harsh since the flap on the seal kept folding in on it self. But evently, I got it in. I also nailed the timing for the timing belt on the first try. A good 6hrs later, I just want to rest.
The easiest part to remove, THE TIMING GEAR SPROKET. . The crank pulley put on more of a fight.
__________________
1996 Ford Ranger XLT, 2.3L 155,xxx miles
1996 Chevy Blazer LT 4x4, 4.3L 180,xxx miles
2006 Kawasaki KLX250s, 250cc 10,xxx miles
Telling your girlfriend that she has small boobs comes at a price
LearjetMinako is offline   Reply With Quote
Old 03-19-2008, 11:47 PM   #13
NathanEdwardDavid
Vehicle Make: Ford
NathanEdwardDavid is on a distinguished road
Default 1996 Ranger 2.3L Timing Belt Replacement
Hello,
My neighbor is trying to replace his timing belt on a 1996 Ranger 2.3L. We couldn't get the crankshaft pulley off, and there is nowhere to mount a puller to it. Is it just stuck? I was advised not to attempt prying it off because there might be some timing sensor pins on the back of it that could take damage. Any suggestions besides the obvious WD40?
Thanks
NathanEdwardDavid is offline   Reply With Quote
Old 03-20-2008, 01:10 AM   #14
Hardwareman
Hardwareman's Avatar
Vehicle Year: 1995
Vehicle Make: Ford
Hardwareman is on a distinguished road
Default
Yeah, you need a puller to get it off. At least I do everytime I have to pull one off. I just use an old universal Craftsman puller I"ve had forever. I think you can rent one for free at your local AutoZone. You have to pay for the tool up front and then when you are finished just return it and you get all your money back.
To put the pulley back on, I just throw it in the oven at 400 for about 10 minutes and then slide it on. Whatever you do, DON"T beat on it. Later.
Allen
__________________
1995 Ranger Extra Cab
2.5 Swap
8.8" w/4.56's and Posi
31" Rubber (Remington Right Now)
Thrush Turbo Muffler
4" RC Lift w/6" SJ Coils
Overbuilt's better then underbuilt. After a 12 pack of beer and a dare from your best friend.
Hardwareman is offline   Reply With Quote
Old 03-21-2008, 06:25 PM   #15
LearjetMinako
Vehicle Year: 1996
Vehicle Make: Ford
Default
Allen
Oops. Don't know about the oven part. But I light tapped it with a hammer on the back end to loosen it. Once it was loose, it went back on easy.
__________________
Old 03-21-2008, 06:44 PM   #16
Hardwareman
Vehicle Year: 1995
Vehicle Make: Ford
Default
Well yeah, you're fine then. I'm talking about actually hitting it with force. A light tap to get it seated should cause no problems. Did you fix the leak?
Allen
__________________
2.5 Swap
Old 07-11-2010, 07:18 PM   #17
982WDRanger
07/2013 OTOTM Winner
982WDRanger's Avatar
Vehicle Year: 1998
Vehicle Make: Ford
I use this vehicle for: Daily Driver
982WDRanger is on a distinguished road
Default
Thanks DaveR
I changed the front one for now, along with the oil pan gasket and that cover gasket that holds the front seal. I also did the oil pump gasket, but not the o-rings because they only shipped me one and it was the wrong size. I'm thinking of changing out the rear main seal right before dropping the engine in because I need to take the engine off the stand anyways to gain access to it. It should only take a couple minutes. What do you think?
[IMG][/IMG]
The new seal's already in in this picture but it was a piece of cake. I drove it in and out with my MagLight....lol. It was the perfect diameter.
Allen
How did you get your crank sprocket off? I have a 98 2.5L and I'm doing the same thing, replacing the front timing cover. I can't seem to get the sprocket off though?
__________________
SAS'dRngr98:1998 Ranger XLT, SAS. Dana30,30-spline,e-locker w/456's. 31-spline 8.8 locked w/456's
982WDRanger is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
