Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 05-18-2013, 02:16 PM   #1
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
escort_gts's Avatar
Vehicle Year: 1993, 2001
Vehicle Make: Ford
Vehicle Model: Ranger, Explorer
I use this vehicle for: Daily Driver
escort_gts is a jewel in the roughescort_gts is a jewel in the roughescort_gts is a jewel in the rough
Default On-Board air using A/C pump
Here is my setup using the stock ranger A/C compressor.
Parts needed with prices. Prices are estimated:
*a 160psi max tank 5 gallons or equivalent $35
*in line oiler 1/2"NPT $4
*manifold w/at least 4 outlet ports 3/8 NPT inlet 1/4 NPT outlets $8
*shutoff switch 90psi on/120psi off 1/4" NPT $10
*safety valve rated within tank max pressure, I used a 150 psi 1/4" NPT $5
*160 psi gauge 1/4 NPT $12
*check valve 3/8 NPT $8
*oil/water separator 1/4 NPT $8
*quick conncect air fittings 1/4 NPT with 3/8" and 1/4" hoses ~$10
*DOT approved 3/8 air line
*misc. barbed and other fittings ~$10
All parts except for brass fittings I got from eBay.
Total; roughly $100 but I got some of the parts for free. So my cost was less than $50
Here is the tank I used. It's for a semi tractor.
I mounted it under the bed behind the axle where the spare tire was.
Had to weld brackets to the frame, was a little smaller than the frame width.
I plumbed the inlet into the air cleaner box. This way I didn't have to use a separate filter. I used 1/2"NPT pipe with two locking nuts at the air box and then mounted the inline oiler to it. And then used 5/8" heater hose from the oiler to the inlet tube for the compressor.
The inlet of the compressor is the top tube. Outlet is the bottom one.
From the outlet I just cut the hose and then used a barbed fitting and then mounted the check valve before the manifold. You can barely see it here.
I mounted the manifold to a bracket attached to the master cylinder. Then mounted the gauge, switch, safety valve and the outlet that runs the the tank with the oil/water filter.
I ended up using the factory a/c relay and used a toggle switch mounted on the dash. Have to open up the relay/fuse box and rewire it; from the fuse panel under the dash I found an unused acc on lead and ran a wire from that to the switch on the dash. From there ran a wire to the pressure switch located on the manifold, then to the relay. From the relay its already wired to run the clutch on the compressor.
For air fittings, I placed one on the rear bumper and in the grill. I used 1/4" DOT air hose but I would like to switch it to 3/8 hose for more air flow.
This setup works great. I can run air tools and air a completely flat 35" tire in a few minutes. Been using it for two years without any major problems. Only thing I had to fix was I originally used a cheap rubber air hose going to the tank. I had to replace the hose after a year because it rotted out from all the road salt. I replaced the hose with DOT approved 3/8" air line.
Sent from my HTC ONE using Tapatalk!
escort_gts is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 05-18-2013, 02:39 PM   #2
LIMA BEAN
LIMA BEAN's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Vehicle Model: Ranger SXY
I use this vehicle for: Doing dirty deed's dirt cheap.
LIMA BEAN has a reputation beyond reputeLIMA BEAN has a reputation beyond reputeLIMA BEAN has a reputation beyond reputeLIMA BEAN has a reputation beyond reputeLIMA BEAN has a reputation beyond reputeLIMA BEAN has a reputation beyond reputeLIMA BEAN has a reputation beyond reputeLIMA BEAN has a reputation beyond reputeLIMA BEAN has a reputation beyond reputeLIMA BEAN has a reputation beyond reputeLIMA BEAN has a reputation beyond repute
Default
Nice The tank looks really close to the shocks but I take it you have not had any clearance issues since you been running it for awhile. Also does the tank have a drain petcock for condensate?
__________________
88 Ranger
http://www.cardomain.com/ride/2459246
"You have come to take our evil black guns? heh heh be right with ya there mister."
LIMA BEAN is offline   Reply With Quote
Old 05-18-2013, 02:47 PM   #3
escort_gts
escort_gts's Avatar
Vehicle Make: Ford
Default
Quote:
Forgot to mention that, but yes it does have a drain valve.
There is plenty of room for the shocks. It might look close in the picture bit its not.
Old 05-18-2013, 03:14 PM   #4
LIMA BEAN
LIMA BEAN's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Default
Good deal. If you added some description font with little arrows pointing to each component this would be great in the tech section for OBA, some folks may need a little clarity on whats what. Great job though.
__________________
88 Ranger
Old 05-18-2013, 04:10 PM   #5
escort_gts
escort_gts's Avatar
Vehicle Make: Ford
Default
I will see what I can do with the pictures and then edit the post.
Old 05-18-2013, 04:42 PM   #6
t0x1k
t0x1k's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
I use this vehicle for: Keeping the wallet on a diet
t0x1k will become famous soon enought0x1k will become famous soon enough
Default
Not sure how you made this last so long. I went through 2 compressors in less than a year, I had it oiled to the point it would use an entire oilier filled every time i went to fill the tank.
__________________
1994 XLT | 4.56 Dana 35/8.8 31 | 35x12.5x15 BFG KM2 | 5.5" suspension + 1.5" spacers + 3" body
1985 | 302 v8 | Tremec tko600 | Torq thrust 2s
t0x1k is offline   Reply With Quote
Old 05-18-2013, 04:55 PM   #7
escort_gts
escort_gts's Avatar
Vehicle Make: Ford
Default
Quote:
Luck?
Don't know, I've wondered the same. I only let the motor idle when the pump is on. Maybe that is why? :confused:
Old 05-18-2013, 04:59 PM   #8
dangerranger83
5.0 HO under the hood!!!
dangerranger83's Avatar
Vehicle Year: 1983
Vehicle Make: Ford
I use this vehicle for: My DD, play toy
dangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud of
Send a message via Skype™ to dangerranger83
Default
I've seen his set-up work in person and its nice.
Sent from my rooted SPH-D710 using Tapatalk 2
__________________
Build thread, 5.0 swap happening now!!!! Click me
5.0 HO carbed, np435 with an np208 transfercase, 32 inch BFGoodrich M/T's, D30 SAS with 6.5 XJ coils, 63 inch leaves in rear.
dangerranger83 is offline   Reply With Quote
Old 05-18-2013, 05:04 PM   #9
LIMA BEAN
LIMA BEAN's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Default
I wondered about longevity too thats why I have a york thats going on mine but same basic system. You should get some plugs to keep junk out of your quick couplers, should be able to get them locally.
http://www.hoseinahurry.com/5600-ser...ug-56-002.html
__________________
88 Ranger
Old 05-18-2013, 05:21 PM   #10
escort_gts
escort_gts's Avatar
Vehicle Make: Ford
Default
I do have one on the rear, not like what is pictured. The front one is disconnected at the moment. So all I have is the rear but have a 50ft coil hose...plenty long enough.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
