Serving Ford Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Forums Info - Technical Info - Other TRS News Photo Galleries Shirts & Decals Parts Store Classifieds
Go Back   The Ranger Station Forums > Engine & Transmission Forums > V6 Forums > 2.9 Liter Forum
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 06-20-2012, 04:34 PM   #13
87RangerXLTct
Year: 1987
Make: Ford
Model: Ranger XLT super cab
87RangerXLTct is on a distinguished road
Default
here's a picture, I'm looking for the coupling that screws into the exhaust manifold and the female connector on the egr tube.Thanks
87RangerXLTct is offline   Reply With Quote
Old 06-20-2012, 08:11 PM   #14
87rangerxlt
Year: 1987
Make: Ford
Model: Ranger
87rangerxlt is on a distinguished road
Default
you try running a tap threw it that is the same threds as the fittings you have? if its close that you shoud be able to run the right tap threw it and make it work
87rangerxlt is offline   Reply With Quote
Old 06-20-2012, 09:04 PM   #15
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: What engine?
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Let me poke in the garage.
I took the original engine out of my 87 and tore it apart. I am not sure what I did with the EGR tube though. The intake manifold is still in the garage, but the heads and exhaust manifold went to Jersey for another member's engine rebuild. I don't really remember where the valve and tube ended up so I might still have them.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Mark_88 View Post
Question: "What year is your truck"?
My Answer: "What part"?
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is offline   Reply With Quote
Old 06-21-2012, 08:35 PM   #16
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Used For: Elevenses
Default
Found the intake, no EGR valve, no tube. Those parts must have been sent to Jersey.
__________________
Old 06-21-2012, 10:31 PM   #17
87RangerXLTct
Year: 1987
Make: Ford
Default
no problem thanks anyway adsm08
Old 06-22-2012, 08:55 AM   #18
Psychopete
Psychopete's Avatar
Year: 1987
Make: Ford
Model: Ranger
Engine: NONE
Class: 2WD
Used For: Working on
Psychopete is just really nicePsychopete is just really nicePsychopete is just really nicePsychopete is just really nice
Default
EGR tubes are a bear - I snapped the tube on my Tempo, but luckily had another engine to take one from.. Either way, it was an epic time vampire. I would be real tempted to swap computers in your case. Saw a 88 manual ecm for a 2.9L for sale, but on another forum. They are around.
Psychopete is offline   Reply With Quote
Old 06-22-2012, 07:01 PM   #19
87RangerXLTct
Year: 1987
Make: Ford
Default
I saw that one pete, except mines a 4x4 that ecm is out of a 2wd. Not sure if that matters
Old 06-23-2012, 09:29 AM   #20
holyford86
holyford86's Avatar
Year: many
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: DD/ offroad beater
holyford86 will become famous soon enoughholyford86 will become famous soon enough
Send a message via AIM to holyford86 Send a message via Yahoo to holyford86 Send a message via Skype™ to holyford86
Default
Quote:
Originally Posted by 87RangerXLTct View Post
Earl thanks very much for the offer but sadly I have a manual trans.
NEVERDONE86 thanks I only have the one fitting that's on the egr now, I scrapped the manifold with the fittings and half the tube attached. Maybe I can source the fitting at a plumbing warehouse or ford dealer?
AllanD thanks for all the info I'm gonna try to just get the egr hooked up for now until I come across a computer
I have a couple of them for manual trans here, I have a 4.0 now so i have no use for them, I believe I have an 88 manual trans, a 92 manual trans and a 90 Cali MAF manual trans. PM me and let me know which ones you want
__________________
86 Ranger, 4.0, M5OD, BW1354M, D35 L/S, 8.8, Detroit, 4.56's, York OBA, 200 amp alt, Dual Batteries, 33x12.50x15 Procomps, Skyjacker 6" class II, Belltech 6400's, XRC8, 63" Chebbies, 339k miles
holyford86 is offline   Reply With Quote
Old 06-29-2012, 08:10 AM   #21
freedom5
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9
Used For: Show and Pleasure
freedom5 is on a distinguished road
Default
Quote:
the manifold thread should be a pipe thread. If you are going to replace it with a copper tube yo can buy a brass adapter going from a pipe thread to a flare fitting. Then you can cut the copper tubing to the right length and use flare nuts.
freedom5 is offline   Reply With Quote
Old 06-29-2012, 11:06 AM   #22
87rangerxlt
Year: 1987
Make: Ford
Model: Ranger
Default
Quote:
hw much you want for the 88 2.9 4x4 manual computer?
Old 06-30-2012, 10:21 PM   #23
87RangerXLTct
Year: 1987
Make: Ford
Default
It's not pipe thread in the manifold, plus it's metric. Couldn't find anything at home depot that would work
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
