| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Ranger Axles Dana 28, Dana 35, Ford 7.5 & Ford 8.8 |
Thread Tools | Display Modes |
#1 |
Building another truck
Year: 1983 & 1996
Make: Ford
Model: Ranger
Engine: 5.0 / 4.0
Class: 4x4
Used For: Dedicated trail rig!
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
I know there has been discussions on the Dana 44 TTB knuckle swap on to the Dana 35 by reaming the ball joint mounts.
And I've seen info on using a D44 spindle on a D35 knuckle that also involves cutting of the brake caliper mounts. Has anyone ever looked to see if you could use rotors from the Dodge Ramcharger Dana 44 that had the 5x4.5 bolt pattern to create a D44 hub swap while retaining the Ranger wheel bolt pattern?
__________________
Some people are like slinkies -- not much good for anything, but they bring a smile to your face when pushed down the stairs. Check out my Blue Oval Militia Profile HERE Vote For TRS In Top 4x4 Sites |
Tweet
#2 |
Premium Member
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: Weekend Warrior
Rep Power: 21 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (8)
As far as I know, all the ramchargers w/ 5x4.5 bolt pattern had auto hubs unless otherwise converted with a spendy kit.
http://ramchargercentral.com/technic...ana-44-138815/ Here's a good read for you. Last edited by brinker88; 06-11-2012 at 03:13 PM. |
Tweet
#3 |
Mall-Rated
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Those Dodge axles had no hubs at all, they used live spindles with cartridge (unit) bearings.
I also recall the bearings were unique to the knuckles (meaning no knuckles are available that would fit them onto a TTB beam). Their wheel bearing setup has a similarly narrow spacing, complicated by the fact you can't even adjust them in a manner to have them hold up like you can the D35's (the bearings may even be smaller on top of that too). I see no benefit whatsoever here.
__________________
'90 Bronco II XLT 5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s '94 Ranger XLT 6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s |
Tweet
#4 |
Premium Member
Year: 1994
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: daily driver, trail ready
Rep Power: 8 ![]() ![]() ![]() ![]() ![]() iTrader: (1)
:/ And I was hoping this might be possible since I'm doing the d44 outers in the next month or so.
Sent from the road while ignoring traffic |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
