Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 03-07-2012, 12:18 PM   #1
TexCaliBII
Premium Member
TexCaliBII's Avatar
Year: 88
Make: Ford
Model: BII/M50D
Engine: 4.0
Class: 4X4
Used For: Enhancing vehicle values around me
TexCaliBII is on a distinguished road
Default Squealing belt?
Hey all,
Anyone else have a problem with belt squeal on the 4.0 in a BII? I have so far replaced both idler pulleys, the tensioner assy 2 NAPA belts and now a Gates belt and the water pump. I thought I had it whipped with the Gates belt, nope since it got cold I'm getting the squeal at start up and until I am driving and get the RPMs up to about 1500 again. Once the truck warms up it seems to be less of an issue. I have all accessories on this motor. Any thoughts?
__________________
Exercise daily! Walk with God and run from the Devil!
Member of ARCTICOFFROAD.COM and United Christian Off Road Alliance
88 BII. XL+, 4.0, M50D, D35 w/ Aussie locker, 8.8 w/ disk brakes, 3:73 LS, 8K lb winch
2004 Expedition, Eddie Bauer with all options and all working!
99 Chevy Silverado, kid hauler
TexCaliBII is offline   Reply With Quote
Old 03-07-2012, 12:58 PM   #2
jakes86
Year: 1986
Make: Ford
Model: Bronco 2 Eddie Bauer
jakes86 is on a distinguished road
Default squeal
It seems like you've replaced almost everything as far as pulleys on it. Did you check all of the bushings? I had a similar problem w/ my wifes 1990 Voyager, I replaced the tensioner which was bad, idler pulley, and several belts and it turned out the bad tensioner took out a bushing on the idler pulley.It made it make a nice squeal especially if it rained or got wet. We replaced that and now it doesn't squeal anymore. Just something you might have missed?
jakes86 is offline   Reply With Quote
Old 03-07-2012, 05:11 PM   #3
Original_Ranger84
Premium Member
Original_Ranger84's Avatar
Year: 1984, 1999
Make: Ford
Model: Ranger
Engine: 2.8L, 3.0L
Class: 4x4's
Used For: Project, DD
Original_Ranger84 is a jewel in the roughOriginal_Ranger84 is a jewel in the roughOriginal_Ranger84 is a jewel in the rough
Default
How about the Power steering or Alternator pulleys? There could be a problem with them or the bearings associated with them.
Also was there belt dressing sprayed on at any point in time that may not have gotten cleaned off?
Also I am assuming this is a serp belt and not v belts?
__________________
99 Ranger DD - 3.0L, 5spd, 4x4, 4 door, step side, 31's, 4x KC driving lights.
84 Ranger Project - 2.8L, 5spd, 4x4, regular cab, long bed, 3" body lift, 31's, 4x KC long ranges, Dual CD player/Blaupunkt Speakers.
Quote:
Originally Posted by Myself View Post
"Tall Trucks, Small trucks, whos got the balls to roll with our trucks?"
Original_Ranger84 is offline   Reply With Quote
Old 03-07-2012, 07:03 PM   #4
TexCaliBII
Premium Member
TexCaliBII's Avatar
Year: 88
Make: Ford
Model: BII/M50D
Engine: 4.0
Class: 4X4
Default
Yeah,
I replaced the idlers after the tensioner and then the water pump and the three belts all in trying to track this down. Never had belt dressing on it, don't like the stuff. This is really bugging me. I tried locating it by using my stethoscope but can't locate it exactly. Thinking of getting a non AC belt and see if the fixes it as I don't exactly need AC just now. The pump was replaced after the squealing started as it was leaking. The only part not changed out yet is the ac compressor hence my thought of using a non ac belt. I'd rather not as I would have no need for it.
__________________
Old 03-07-2012, 07:06 PM   #5
4.0B2
MALL CRAWLER POST WHORE!
4.0B2's Avatar
Year: 1988
Make: Ford
Model: Bronco II
Engine: 4.0 v6
Class: 4x4
Used For: Taking my Money
4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute
Default
have any oil leaks that could be getting on bearings, pullys, or the belt?
4.0B2 is offline   Reply With Quote
Old 03-09-2012, 07:12 PM   #6
Original_Ranger84
Premium Member
Year: 1984, 1999
Make: Ford
Model: Ranger
Engine: 2.8L, 3.0L
Class: 4x4's
Default
Try getting a really lotiony soap like a bar of dove and hold it against the belt while its running on both sides, if the belt or the contact point for the belt on the pulleys is to blame then the squeak should go away becuase the soap is lubing it (it may just reduce the sound as well) but the you would know if it was the belt or if there is a bearing problem somewhere else.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
