Ok, well I made some progress but I have a bit of a dillemma. Maybe someone can help me figure it out. But first the progress.
The axles are good, turned out the leakage was just a cracked driverside seal.
So here we are at the start.
So the frame clearancing. The rear lip of the crossmember is about 1/2"-3/4" lower than the front. This is a problem, need to sit vertical, or even lean towards the rear of the vehicle.
The second clearance problem. The pumpkin hits the frame about 4"-6" before the bumptop. This needs to be removed.
Nice final weld. Shiny. I did 2 more passes after this one.
Trying to limit my inhalation of rust. I hate the black boogers.
And its under!
How it sits now
So! The beams clear everything all the way to the stock bumpstop, but at the stock wheelbase width the spring perches on the beams are about halfway under the frame rail.
There is no way to fit a spring on there.
I tried drilling new holes to move the beams outward, but now the center u joint binds when the beams get within 2" of the bumpstop.
