| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Ranger Axles Dana 28, Dana 35, Ford 7.5 & Ford 8.8 |
Thread Tools | Display Modes |
#1 |
Year: 1993, 1990
Make: Ford, Volvo
Model: Ranger, 240 DL Wagon
Engine: 4.0, 2.3
Class: 2wd
Rep Power: 11 ![]() iTrader: (0)
Hi, I was wondering how common were factory 4.10 gears in the Bronco II line as I am looking to upgrade from my 3.73s. Also will the front and rear ends out of a ranger around the same year swap in?
Thanks in advance, Josh |
Tweet
#2 |
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 396W
Class: 4x4 Extreme
Rep Power: 15 ![]() ![]() iTrader: (2)
4.10 gear ratio is probably the least common although they are out there. As far as the front and rear being the same for each vehicle, yes and no. Your BII will have a 7.5 rear axle. The Ranger 7.5 rear axle is not a direct bolt in, it is wider than the BII axle and the mounts will need to be moved. If you are mechanically inclined and have the tools you can to either, cut and weld new mounts for the Ranger axle or install the Ranger gear set into your current housing. You will have a Dana 28 front although I believe the Dana 35 may have been available in 89 and 90, don't quote me on that though. As long as you have the same third member as in your vehicle wheter it be a D28 or D35 all you will need to do is take your current third member out and install the one with the 4.10s, unless you just bought a ring and pinion then it will need to be installed inplace of the 3.73 gear set. As far as installing gear sets, if you don't know what you are doing nor have the tools it is best left to a person with the proper knowledge. If installed inproperly not only will they be noisy but will acceleate the wear of the gear set.
Matt
__________________
88 Ranger XLT 4x4, no drivetrain, no frame, nothing....new stroker, frame and drivetrain in the works |
Tweet
#3 | |
Year: 88-95
Make: Ford-Dodge
Model: BII-Dakota
Engine: 4.0-5.2 Turbo
Class: Real 4WD, 3WD.
Used For: Going where I point it-Going fast
Rep Power: 24 ![]() ![]() ![]() ![]() ![]() iTrader: (1)
Quote:
__________________
88 Bronco II, 4.0L, M5OD, 4.56s, Aussie Locked 8.8/D35, 1354M, 34" LTBs 95 Dakota CC, 5.2, 5 Spd, 2WD,Turbo, Megasquirt, 3.55s, Locked |
Tweet
#4 |
Yeah, I built that.
Year: 1997, 1994
Make: Ford
Model: Ranger, F350
Engine: 4.0, 7.3
Class: 4x4 Extreme
Used For: Working and Wheeling
Rep Power: 10 ![]() iTrader: (28)
not very common but they are out there. it is more dependant on how lucky you are when you visit the junkyard.
__________________
Horsepower is how fast you hit a wall. Torque is how far you move a wall. http://www.therangerstation.com/foru...ad.php?t=21890 1994 F350 7.3L PSD, 5spd, DD/tow rig, 2wd for now... 1997 Excab/4.0/5spd/Manual1354/4.88/locked F/R /35"BFG MTs/WarnXD9000i/6"lift/HYDROBOOST!!/Extended radius arms/Wheeling only. |
Tweet
#5 |
Year: 1988
Make: Ford
Model: Ranger XLT
Engine: 396W
Class: 4x4 Extreme
Not all Ranger 7.5's bolt in. I was going to put an extra late-88 Ranger 7.5 in my early-89 BII. The spring mounts were not the same distance apart. I didn't think to check that before I went to bolt the axle in.
Matt
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
