Serving Ford Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Forums Info - Technical Info - Other TRS News Photo Galleries Shirts & Decals Parts Store Classifieds
Go Back   The Ranger Station Forums > Engine & Transmission Forums > V6 Forums > 2.9 Liter Forum
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 07-30-2009, 02:38 PM   #1
JuJu1289
JuJu1289's Avatar
Year: 1987
Make: Ford
Model: Ranger
Engine: 5.0
Class: 4x4
Used For: Disturbing the Peace
JuJu1289 is on a distinguished road
Default 2.9 Oil Leak
So ive just replaced the head gaskets along with every other gasket in my 2.9 87 ranger. Fixed my white smoke problem but now i have an oil leak(looks like its coming from the left side). Along with the oil im getting smoke strait from under the hood which is more than likely the oil burning. I thought it might be the valve cover leaking oil out but i took that off today and cleaned it very well and sealed the bolt holes with some RTV. Anyone have a thought before I take it to a mechanic?
JuJu1289 is offline   Reply With Quote
Old 09-09-2009, 11:00 PM   #2
arineod
Junior Member
arineod's Avatar
Year: 1986
Make: Bronco II 4x4
Engine: 2.9L
Class: 4x4 4" lift
Used For: Everything
arineod is on a distinguished road
Default
what did you come up with?
arineod is offline   Reply With Quote
Old 09-09-2009, 11:35 PM   #3
poweranger84
poweranger84's Avatar
Year: 2000
Make: GMC
Model: Slownoma
Engine: 4.3
Class: 4X4
Used For: daily...pain in the ass.
poweranger84 is an unknown quantity at this point
Send a message via AIM to poweranger84
Default
could possibly be the head. you might not of tightened one of the head bolts all the way. the same thing happened to my freinds neon. he replaced all the gaskets from the head up and had the leak
__________________
Tell me I can't...and I promise I will
1989 Metro, 1984 Ranger 4X4, 1991 Colt, 1986 Ranger STX, 1986 F150, 1994 Pathfinder, 1994 Ranger, 2000 Sonoma 4X4
LOUD LOW AND SLOW
poweranger84 is offline   Reply With Quote
Old 09-11-2009, 09:58 AM   #4
cocoasranger
cocoasranger's Avatar
Year: 1989
Make: Ford
Model: Ranger
cocoasranger is on a distinguished road
Default
Most likely the valve cover gaskets are still leaking. Sometimes it takes a couple tries to stop them from leaking. The oil drops onto the hot exhaust manifold and clouds of smoke roll out from under the hood. I could even smell burned oil in the cab with the windows closed on mine.
Search valve cover gasket on this site and you will find numerous threads on what to watch out for when installing them. I used rubber/cork gaskets, but would use the blue neoprene if I was to do it again.
__________________
89 Ranger 4wd std. cab, long bed w. 2.9L and Mazda M5OD R-1 trans. Manual 13-50 transfer case, 10 clutch and starter upgrade. Manual locking hubs, explorer leaf spring upgrade, 93-94 clutch master upgrade for better feel.
cocoasranger is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
