Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 03-09-2009, 01:26 AM   #1
Kona
06/2014 OTOTM Winner
Kona's Avatar
Vehicle Year: 1991
Vehicle Make: Ford
Vehicle Model: Ranger Super Cab
I use this vehicle for: everything
Kona is on a distinguished road
Default Belltech 6400 Shackles
I read about these for ages, thought maybe one day, then I got a deal on 33" TrXus M/T 's and needed more room. Going to do the 4" - 6" spring swap in the front and to balance it out Belltech shackles in the rear. The shackles are a well finished and solid looking part , about 2" longer then stock but you only get about a 1 - 1 1/2" in lift due to the spring displacing them further rearward. The only trouble installing them was taking the old ones out ( I have submitted a article for the library). I seem to have gotten a easy 1" - 1 1/2 " of lift AND a smoother ride. So as of 2 days after install I heartily endorse this product, I will update later in the year after I have a chance to wheel them.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
__________________
91 Ranger XLT SCab 4.0L ,5 Spd,4.56 gears, Spartan locker, Skyjacker 6" w Stock radius arms, Explorer leaf springs, Belltech 6400 Flowmaster 40, 35" Cooper STT's
Kona is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 20B2FF503DCF74 Expires: September 28, 2018
Old 03-09-2009, 11:55 AM   #2
crawlin91
crawlin91's Avatar
Vehicle Year: 92
Vehicle Make: Ford
I use this vehicle for: running stuff over
crawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud ofcrawlin91 has much to be proud of
Default
yeah I finally got around to installing mine, last night actually. removed the f150 blocks I had in the rear and replaced my stock shackles with the belltechs. I kept about the same ride height (6 in lift) It definately free'd up alot of flex in the rear and my truck runs quite a bit smoother.(the bushings in my old shackles were shot to shit. fairly easy install, had to cut about a foot off of my exhaust to keep it from rubbing. Didnt cause any driveline vibration despite a slight change to the pinion angle from removing the blocks on the 8.8.
Id recommend them to anyone seeking a little lift or additional flex.
crawlin91 is offline   Reply With Quote
Old 03-14-2009, 11:55 PM   #3
irishblessing
Lurker
Posts: n/a
Default
wait kona said it you lose a lift and crawlin91 said it get you a lift which one is it
Old 03-15-2009, 02:52 AM   #4
Kona
Kona's Avatar
Vehicle Year: 1991
Vehicle Make: Ford
Default
Quote:
What I meant (and will fix) is that the shackle is 2" longer then the stock one BUT due to the spring pushing the shackle a little further back you do not get 2" of lift out of it JUST 1- 1 1/2 " total lift.
__________________
Old 03-15-2009, 12:48 PM   #5
irishblessing
Lurker
Posts: n/a
Default
alright i got it thanks
Old 03-23-2009, 01:01 AM   #6
Loanranger
Loanranger's Avatar
Vehicle Year: 1989/ 1972
Vehicle Make: Ford/ Fordzuki
Vehicle Model: Ranger SC XLT/ Mutt?
I use this vehicle for: Daily driver/Jeep Recovery
Loanranger is on a distinguished road
Default
Agreed, great shackles for the money. I've been running mine for about 3 years now with no problems, excellent flex, and great ride.
The reason you only get 1-1.5" of lift is due to the fact that you're only lifting one end of the spring 2". If you lifted both ends of the spring 2", you would get more like 2" of lift. In fact, it's the exact same reason 1" of spacer under the front coils will net you 1.5" of lift.
__________________
Sold the ranger
Fordzuki, 72' Suzuki LJ20, w/ '97 2.3 and M50d, locked, geared, linked rear, 34x10.50s
Daily driver, '86 Suzuki Samurai, stock other than geared t-case and a rear lockright.
Loanranger is offline   Reply With Quote
Old 05-07-2009, 07:14 PM   #7
jarhead2010
Junior Member
Vehicle Year: 1999
Vehicle Make: Ford
I use this vehicle for: daily driver
jarhead2010 is on a distinguished road
Default
this could very possibly the dumbest question, but im goin to ask anyway.
Im going to crank my torsion bars and add the shackles in the back, should i replace my shocks with some that are a little longer or just keep the stock length? thanks for anyone who answers
__________________
aut viam inveniam aut faciam- ill find a way or make one
jarhead2010 is offline   Reply With Quote
Old 05-24-2009, 01:21 AM   #8
Kona
Kona's Avatar
Vehicle Year: 1991
Vehicle Make: Ford
Default
Maybe, check how far your wheel on a given side drops with no shock and it it is less with the shock on then you need longer ones.
__________________
Old 09-02-2009, 10:34 PM   #9
99iowa4x4ranger
Junior Member
99iowa4x4ranger's Avatar
Vehicle Year: 1994/2004
Vehicle Make: Ford
Vehicle Model: Ranger/f-250
I use this vehicle for: dd/beater/toy
99iowa4x4ranger is on a distinguished road
Default
do you have a part number on that? or a link to where you ordered them?
__________________
2004 f-250 Crew cab 4x4 6.0
1999 s-10 zr2
1994 Ranger 2.3 5spd
Looking to get rid of the chevy for another ranger
if it cant be fixed with a hammer.. its an electrical problem
99iowa4x4ranger is offline   Reply With Quote
Old 09-02-2009, 11:15 PM   #10
wahlstrom1
J-man HD Mech
wahlstrom1's Avatar
wahlstrom1 is a jewel in the roughwahlstrom1 is a jewel in the roughwahlstrom1 is a jewel in the roughwahlstrom1 is a jewel in the rough
Default
Belltech is the brand, 6400 is the part number. IIRC there is also 6700's which will give you more lift but possibly awkward handling due to axle shift from LONG shackles.
__________________
UNDER RE-CONSTRUCTION
97' U.A. Ranger, Bent and Broke...
Quote:
Originally Posted by Kyle M. View Post
LOL, wheres the loony bin, cuz we be crazay
wahlstrom1 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
