Serving Ford Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Forums Info - Technical Info - Other TRS News Photo Galleries Shirts & Decals Parts Store Classifieds
Go Back   The Ranger Station Forums > Engine & Transmission Forums > V6 Forums > 3.0 Liter Forum
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 12-01-2011, 02:10 PM   #1
iplayloudly
Year: 1996 2004
Make: Ford Ford
Model: Ranger XLT 2.3L 2WD Ranger Edge 3.0 2WD
iplayloudly is on a distinguished road
Default Odd coolant leak / Starter oil leak??
2004 3.0 edge 2wd
So first of all, I have coolant running down the oil pan on the passenger side, and dripping off the drain plug. I know its coolant because I have dye in it. I also smell burning coolant when the truck is hot. Nothing is leaking around the top of the engine, nor is the water pump / gasket leaking. All I can think of is maybe the lower intake at the back of the engine. But I can't seem to get a good view of it. Anyone else had this problem?
Also, I noticed some kind of oil (not engine oil, its a dark gray color) leaking out of a hole on the bottom of the starter. What is heck is this?
iplayloudly is offline   Reply With Quote
Old 12-01-2011, 02:27 PM   #2
tbirdsps
tbirdsps's Avatar
Year: 1992
Make: Ford
Model: RANGER XLT
tbirdsps has a spectacular aura abouttbirdsps has a spectacular aura abouttbirdsps has a spectacular aura about
Default
Still coolant more than likely coming out of the starter. The coolant is washing out the gunk in the starter. Starter bearing failure coming?
Consider that it could be a "freeze" plug leaking either on the back of the head or the rear most plug on the engine block.
tbirdsps is offline   Reply With Quote
Old 12-01-2011, 03:07 PM   #3
06RangerXLT
06RangerXLT's Avatar
Year: 2006
Make: Ford
Model: Ranger XLT Extended Cab
Engine: 4.0L
Class: 2WD Country
Used For: Shenanigans
06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of06RangerXLT has much to be proud of
Default
yea im gonna say coolant out of the starter as well. but in that area, if its auto, your torque converter may have a leak and is slinging ATF in there. or the input seal in the trans. theres a few things. smell and taste is the best diag.
__________________
Camburg BTF mid-travel kit, 64's, 33x12's,E-Fan Conversion, 4.56 8.8, McNeil Glass
06RangerXLT is offline   Reply With Quote
Old 12-02-2011, 06:12 AM   #4
iplayloudly
Year: 1996 2004
Make: Ford Ford
Default
Ok so how does coolant get into the starter? I've never heard of a starter with coolant lines running into it...
Old 12-02-2011, 06:32 AM   #5
locovaca
Year: 1993
Make: Ford
Model: Ranger XLT
Engine: 3.0
Class: 2WD Stock
locovaca is on a distinguished road
Default
If you're absolutely sure that's coolant there's only two things above there that could be leaking it: a freeze plug or the lower intake. There aren't any (factory) hoses running above there.
locovaca is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
