Broco II "bucks and jerks"
chrislang
Newbe here with 86 2.9l 5 speed.
I know you guys must have had this discussion come up, but I searched and cannot seem to find an answer.
Issue: Starts up and idles fine. When taking off it is fine, if you rev the engine up on take off. Idles fine, and will rev up fine parked in neutral. It stumbles and jerks violently upon acceleration between shifts. I just bought this, because it is in such good shape. No rust, immaculate interior.
The guy I bought it off of has tested virtually ALL of the sensors, changed both fuel pumps, drained the tank, replaced the computer, new plugs and wires.... NO CHANGE...
Temp. does not seem to matter, IE: does not start this acting up when hot, it can happen anytime. Vacuum issue,(can't find any) Timing? (set 10deg. BTDC)..Cold spark? Maybe I need to use the Motorcraft 42Cs? (not sure whats in it now)
The motor was swithed out to one with a lot less miles. The guy I bought it from wasn't sure of the year although he said it was newer.
Could it be the motor mounts?? I have a truck that acted like that when it needed motor mounts.(Runs fine in 5th gear when your accelerating) Seems to happen most when you are letting off the accelerator, then resuming acceleration.
I know you guys must have discussed this ad nauseam in the past. If so, please point me to the link.
I really like the BII and am determined to find the issue. I hope you guys can help. Any and all comments will be appreciated!!
Thanks in advance!
Chris
85_Ranger4x4
17,775
SW Iowa
It is a Bronco, did you not see the bucking horse badge? :icon_twisted:
You might install a vacuum gauge in it and see what it is doing realtime as you drive it.
Probably a nonissue but you did unplug the dizzy when you set timing right?
chrislang
By dizzy, do you mean the SPOUT plug? I did indeed unplug it. Does that stand for SPARK-OUT? It is not one of those typical TFI things about getting hot, then shutting off. As long as I am accelerating it seems to do ok. But in between shifts, it bucks when pressing the throttle as you release the clutch.
Thank you all for any info, as I am at a loss of ideas.......
:icon_confused:
Danni84
KS
2.8l 104k miles & 2.9l 245k miles
"Seems to happen most when you are letting off the accelerator, then resuming acceleration"
I dont know if the 2.9 has it or not but my 2.8 did that and the EGR valve was stuck closed from carbon build up. Finally got it diagnosed after the 3rd mechanic looked at it. EGR valve and timing had it running well again.
85_Ranger4x4
17,775
SW Iowa
Yeah, dizzy = distributor = spout plug (implied, sorry)
chrislang
Thanks Dannie84!
I'll try that this evening or tomorrow. It can't hurt!
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
Sounds like a faulty throttle position sensor
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Have you checked for play in the distributor shaft?
tdjar
I have an '86 as well and it does the same thing except it happens when I try to maintain a constant speed. Doesn't matter what gear I'm in or what speed I'm going. I haven't been able to get at this yet 'cause the input bearing went in the tranny , it is going back in this weekend, then it will be diagnosis time. I will post what I find and hopefully we can figure this out
