Timing marks on a '89 2.3 - New belt install
Fairlaniac
10
Denver, PA
I'm in the process of putting another engine in my '89 Ranger. I'm putting a new timing belt in the newer engine. I am wondering if the timing mark on the aux. sprocket has an alignment point? I have the cam sprocket aligned, crank aligned and on TDC. I accidentally put my hand on the aux. sprocket as I reached for a toll and turned the sprocket without the belt in place. This is why I was wondering if the aux. sprocket has an alignment point. I think all it does is drive the oil pump, am I correct? I could not find anything in my Haynes manual about this.
Thanks,
Fairlaniac
10
Denver, PA
No help!
That site pretty much has exactly what the Haynes and Chilton manuals have. Here is a picture of my engine. The aux. sprocket has a timing point on it (look for the red "X"), does that align with anything for proper timing? I have a '95 Ford service manual and it shows on a '95 Ranger 2.3 there is a timing mark on the cover that aligns with the diamond shaped mark on the aux. sprocket. I just want to be sure tha tmy '89 does or does not get aligned with any other mark? As I said, I disturbed the sprocket when I accidentally rotated it with the belt off.
Thanks,
scotts90ranger
4,230
Dayton Oregon
2.3 Turbo
'89 doesn't have a cam sensor, so the aux sprocket doesn't matter, just get the belt on it, all it does is turn the oil pump
Kirby N.
March Truck of The Month
