Ranger Bed Bolts? Anyone know specifics?
NewShockerGuy
NOVA, DC
2.3
While I am doing other stuff I am going to replace the bed bolts and clips.
Found them online. Problem is they don't specify length. I have the following part numbers/links. Note that I want to stick with OEM, I do not want Dorman or any other kit out there. I am OK with paying $100 for bolts and nuts from Tasca.
Does anyone know which one is which? IE: Which one is the longer bolts that are attached at the front of the bed near the cab? Those are the two I really need to replace as mine were very rusty.
https://www.ebay.com/itm/FORD-OEM-98-11-Ranger-Frame-Mount-Bolt-N806252S103/252805064228?hash=item3adc5b2624:g:XZQAAOSwnK9ZOLFU
https://www.ebay.com/itm/FORD-OEM-98-11-Ranger-Frame-Mount-Bolt-N806251S103/252961188004?hash=item3ae5a968a4:g:k2EAAOSww9xZN49B
On Tasca Ford they have pictures of the bolts but I can't tell for the life of me which one appears to be slightly longer (by about an inch)
Bolt 1:
https://www.tascaparts.com/oem-parts/ford-mount-bolt-n806251s103/?c=Zz1ib2R5JnM9ZnJhbWUtY29tcG9uZW50cyZpPU1EOTgyOTM1JnI9MTImYT1mb3JkJm89cmFuZ2VyJnk9MjAwMSZ0PXhsdCZlPTItM2wtbDQtZ2Fz
Bolt 2:
https://www.tascaparts.com/oem-parts/ford-mount-bolt-n806252s103/?c=Zz1ib2R5JnM9ZnJhbWUtY29tcG9uZW50cyZpPU1EOTgyOTM1JnI9MTEmYT1mb3JkJm89cmFuZ2VyJnk9MjAwMSZ0PXhsdCZlPTItM2wtbDQtZ2Fz
Thanks for any help.
-Nigel
saskbill
6
Saskatoon, SK CANADA
Well, going by the pics from the links you posted (Tasca), Bolt 1 is #12 in the picture (click the diagram at the bottom to get the note), which would make Bolt 2 #11Bed Bolts.JPG (the front, longer bolts):
NewShockerGuy
NOVA, DC
2.3
Yep I get that, but what I am asking is which one is the longer bolt of the two? The picture reference of 11/12 don't indicate at all the length of the bolts nor whether they are the front bolts near the cab or the rear bolts at the end of the tailgate. I know I need 6 bolts. Two long, four shorter. But can't tell from the part numbers or pictures which one is the longer/shorter bolt.
-Nigel
If you ask me, just spend $45 on the whole set from Dorman. 6 new bolts and nuts.
