PATS Bypass
PlumCrazy
2014 Truck of The Year
168
Millersport, OH
Solid Axle Swap 4x4
Is the anti theft on a 98-00 Ranger just a stater interupt?
If i was to swap PCMs and it was not programmed to keys, could I turn the key to run and jump the starter relay to get started? Or is the fuel pump also disabled?
I will get it programmed, but I want to make sure it runs first if possible.
-PlumCrazy
Crossthreader
I'm not sure exactly what is shut down by the PATS, but it is more than a starter interrupt. I suspect it stops ignition and fuel injection. I have tried to bypass mine, and have even removed the PATS module, but it stops the PCM from allowing an engine start. If you hold a programmed key near the switch, it will start with an unchipped key, and continue running after the programmed key is moved away. It seems as if the PCM needs an OK to start signal from PATS before anything will happen.
Paul
PlumCrazy
168
Millersport, OH
Solid Axle Swap 4x4
My problem is I dont have the key for the truck the PCM came from. I only have the key for my ignition.
-PlumCrazy
They were all different. Some of the early ones were starter interrupt only, some were fuel system interrupt only. Some were both.
I would think that a 98 to 2000 would probably be starter only, but the manual doesn't say.
PlumCrazy
168
Millersport, OH
Solid Axle Swap 4x4
Ill know here soon. My new PCM is in the mail....
clearyskustoms
in my 2002 its just shut off the fuel. where did you get computer reprogrammed
IAmTodd
Johnstown, PA
In my 2000 Explorer it was fuel. It would crank until the battery was dead.
PlumCrazy
168
Millersport, OH
Solid Axle Swap 4x4
I didn't get it programmed. Just bought a 5 speed PCM.
-PlumCrazy
Kirby N.
March Truck of The Month
