What size tires should i run?
Skeleranger
Davis, Illinois
FORD
i have and 02 ranger with the torsions cranked so im sitting pretty much level and i just put on a 3inch body lift. im getting some 15x10 steelies but my question is should i run 32x11.50's or 33x12.50's and if i do run 33's will i rub at all even if i hit some big ruts? thanks for any advice.
97BlackBetty
Norman, Ok
Probably the 33's I know LittleBigFoot is clearing 35's with T-bar crank and 3 inch body lift. Honestly with the T-Bars cranked you arent gonna be flexing to much up front anyways. So my vote is 33's.
PaleBlue90
5
Aurora Colorado
FORD
2.3,2.9 and 4.0
yea he is...but hes rubbing on the t-bars when turning sharply lol. just make shure to regear if you can. it will save you drivetrain the stress.:icon_thumby:
Skeleranger
Davis, Illinois
FORD
thanks
true, the ride is def a lot stiffer with the t-bars cranked, i think i will go with some 33's, if all else fails i can trim, i just measured it out and i have about 4 inches to play with after i put a 33 KM on, which come out to 32.8's. how much would new gears cost, 4.56's are all i prlly need.
PaleBlue90
5
Aurora Colorado
FORD
2.3,2.9 and 4.0
im not shure what does your truck have for a motor/tranny?
never mind your profile says you have a 4.0, do you have a auto or 5speed?
CTswampyankee
Brooklyn CT
302HO
My buddys running 33 12.50 on his 99 ranger. Hes got a 3in body, bars cranked, and 3in shakle in the rear. Thay look an work alsome!
Skeleranger
Davis, Illinois
FORD
i have the 4.OL six, with the auto trans, i have 4.10s that came stock, also i have a few power adders with a trottle body spacer and a cold air intake which helps. exhaust is coming soon. i appreciate all the tips
Kirby N.
March Truck of The Month
