Sounds like crap
00srad600
Scenery hill pa
2.3 2.9
Ok the other day I was driving and smashed the gas to the floor and it sounded like it was going to die popping and bogging changed the fuel filter air filter plugs wires cap rotor still doing it any ideas
4.0B2
151
Walls, MS
4.0 v6
What about other sensors? O2? Clean your iac?
Are the cats stopped up? How's it run under normal acceleration? How's your fuel pressure? There's lot of options you should check out
00srad600
Scenery hill pa
2.3 2.9
Cats are new had to replace them for emissions if you slowly raise the rpm it's fine or with the clutch in its just under hard acceleration ran sea foam didn't do anything
RustedRanger
5
Farmland IN
2.9L
Good idea to run it with a fuel pressure gauge on and see what it does.
a31ford
Electronics GURU
26
Brandon, Manitoba
about 2500 RPM is when it starts to act up ? after it's warm ?, but fine when cold ?
Greg
